Missfire Boost@4500-5500 RPM - The Answer! (for me at least!)
hey guys, how much does it cost to gap the coils?, as i'd like to try this out, since my car misses heavy anything over 7psi!!!, who does this sort of thing, and how much do i need them gapped, i got stock coils.
You gap the spark plugs, not the coils. If you are running more than stock boost you should be running a smaller gap than 1.1mm, most use 0.8mm gap. I use NGK Copper plugs.
Have a look back through the beginning 3-4 pages of this thread and you'll see how to tape up the coils with electrical tape, or use some other type of insulator on the coils (like araldyte glue around the coils). The coils may either have a very tiny crack in them, or have a discolouration due to arcing.
New plugs gapped correctly and further insulating the coils will go a long way to solving your missfiring issues.
Fixxxer :D
There were too many pages before this for me to read :)
But i found the quickest easiest solution for me was to just buy a set of Splitfires and wach them in!!
The car runs like a dream now, i just wish i had them put in 1/2 yr ago now!!!
Just buy the splitfires. 500 from perfectrun.com.au any other fix is temporary. When I pulled them out of the box my first thought was "woah.. nothing's gonna arc through THAT" You have to pull them out to do the taping or whatever, so might as well pull them out once and be done with it.
From the other thread here, I just noted last week that i covered them with araldite over 17 months ago, and not a single hickup yet. I wouldn't call that temporary.
But not everyone's coils are simply cracked. There could be some other issue...
It's worth the try, my $5 and 1hours effort has come a long way...
Guide to fixing missfiring issues.
Step 1: Gap spark plugs to 0.8mm if you're running over standard boost. (Copper plugs seem to work fine and are cheap). If this does not work try Step 2.
Step 2: Insulate the coils with good quality electrical tape, or for a more permanent approach, araldite them. If this does not work, try Step 3.
Step 3: Buy some splitfires.
I don't think 2 cars are really the same. Mine had major missfiring issues and major discolouration due to arcing on ALL the coils. Mine was solved with just Step 1. Does not missfire at all on boost anymore. If/when it does start missfiring again I'll change the plugs and look into the araldite trick before spending over $500 on splitfires.
Fixxxer :)
  • 3 weeks later...
I would just like to add a little bit to this massive thread. My 25DET is getting really bad with this 4k rpm miss ............and I run Splitfires, so no solution is permanent.
Edit: Fixed it. Car ran great last night then like crap this morning. I ran some errands and it wouldn't start after about one hour of operation. I managed to start it and it wouldn't rev above 2000 rpm, I also noticed the AFR showed that the injectors weren't pulsing above 2000rpm but the AFM voltage was fine. I nursed it home and threw on a spare CAS I had laying around, problem solved :P No more misfires, pulls to redline, no more sputtering. Finally.
Edited by mabru
  • 3 weeks later...
I changed the plug to the original spec for GTT (Guess its platinum) heat range 6. As for NGK copper, what s the code part number & heat range are u guys running? Hope this time it's fix the misfiring (hiccup). Last resort would be Splitfires coils.
Ive had the SLIP, ENGINE AND TCS lights come on everytime i start for about a month now, it ocmes on as soon as the engine warms up.
And just since yesterday its driving like a piece of crap. If you throttle it, it backfires constantly like some of the pistons aint goin.
I tried looking for the coil packs on the R34 but i couldnt get to it. ANy help on this would be great.
Guys...believe i or not.....hahahaha I managed to fix d problem. I can say it's my mistake for overlooking the power supply from the battery when i install amp & woofer for my listening pleasure. although it was bought brand new 2 month ago but the capacity or quality (locally made) wasn't up to task for the all the R&B bass & swingin house music!!.
My part supplier mentioned to me that quite a few GTT owner has the same problem as me, some even change battery (other makes) more than twice. It seem the original battery is specially made for our car & last longer.
So I went for a long drive (without my player switch on) and suddenly the misfiring begin to disapear as i drove longer, downshifting & open throttle to clean up all the carbon, bit by bit until it can handle full throttle without any hesitation. Engine now purrs like a kitten with very neutral exhaust smell (used to smell rich/lean..).
Hope my experienced would solved other owners in future. Many thanks guys for all the feedback...now mmmm Boost controller!! hehehehe
Hi Booya,
Mine had the same TCS off & SLIP light on on some occasion. Best is to switch engine off, then start the car again. If it is still on then try giving it a rest for 5- 10 mins. Usually mine goes off after that. If you are in a hurry then take it for a short drive then stop and restart again. Everything will be back to normal. Not sure the battery solution would rectify this problem too.
Hi guys, ever since i bought my 34 GTT, it has had (sometimes) a miss at 4500rpm, usually when i would first gas it after it warmed up etc, and i was starting to get really annoyed with it. After reading this thread i pulled out all my coils and had a good look at them, but they looked brand new. So then looked at the plugs, an saw that they were iridiums with a 1.1mm gap. After gapping them down to .7mm, and driving the car even after it first warms up, the miss is GONE! :D I can't beleive it was such a simple problem! Thanks for your help guys. :P Has anyone with a 34 fitted an safc? an did it make much of a difference, power wise etc?
Well tried the battery option last night removing all stereo components and thats definately not whats causing it.
Ill have to try to get to ther dam coil packs this weekend and pull out the sparkies and regap them.
Otherwise ill take it to a mechanice to have a look at. I checked the coil packs last night just by peaking under the rocker cover but i couldnt see any sparks.
It even started iddling funny when i first started the car COLD!
gotta take the whole coil pack out and check for cracks in the coil pack.. just by looking at them on top wont tell you nothing
It can help, he was checking for sparks in the dark through bad coils, not looking for cracks in the top. If there's no sparks it doesn't mean the coils are good, but if there ARE sparks, then the coil is definitely faulty somehow.
    • sold listed as a Tomei LSD 1.5 Way For 1998+ Nissan Skyline ER34 25GT RB25DE w/Open R200 https://www.ebay.com/itm/174006114594?campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=&mkrid=711-53200-19255-0&loc_physical_ms=108689&loc_interest_ms=&campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=71883f2ccc571356e0a757bc7adfdde2&mkrid=710-53481-19255-0&loc_physical_ms=108689&loc_interest_ms= it went in like butter all gears, alignment, back lash etc, rotation and clearances correct, and if rolling all rotates smooth and free when coasting down road , clutch in or out over 10 mph smooth... its the binding, clunking and jerking from a stop that is most concerning, also seems like its going to tear the tires off in 10 miles of normal road driving.
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
