ok its time to get the ball rolling on SAUVic's social events (pun intended). the start of the school/uni holidays (well for me atleast) means we have plenty of time and nothing to do.
DATE: 13th June 2010
TIME: meet time 7.30, games start after 8pm
PRICING: $15pp gives you 3 games, and whatever foods you want to buy
come on people lets find out who among us can really handle their (bowling) balls. once i give this a little bit more thought, i'll post up the actual meet time cos we might meet somewhere else and do a mini cruise to chaddy. that way we'd have more chance of parking in a bunch. also the possibility of kebab run afterwards for the regulars and who ever wants to tag along.
we have booked 5 lanes at AMF. for approx 20 ppl, should take 1hr and 45min according to the dude at the counter
this is an Unofficial event so newbies and non-members welcome. great way to make a new friend or two in the club.
luv,
Basti
for those who wanna meet up earlier, usual meet spot at monash uni multilevel carpark at 7pm. we will then drive over to chaddy
https://www.sau.com.au/forums/topic/323687-sauvic-bowling/
  • Replies 77
Might bring my own bolwing bowl but that might be a bit nerdy lol
Nerd alert :blink:
Unless it's got a skull crystalised in it...
dont know how to.
Pick up ball, roll on ground...done!
i could possibly be aroused by said activity
He had you at balls...
Hey i work for AMF (but not at Chaddy).
Sunshine Bowl RULES.......
Hook us up brother!
https://www.sau.com.au/forums/topic/323687-sauvic-bowling/#findComment-5277095
    • There are black hose clamps as well if you care. Plazmaman for example sells some: https://plazmaman.com/product/black-hose-clamps-premium-quality-stainless-breeze/
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
