Just get a new one. I got mine replaced at a windscreen place. Ring around, I found prices varied from $300-$500. I ended up getting it for $200 because they screwed up the invoice and forgot to add labour on to the price.
Aftermarket ones are ment to be better because they have the lamination inside and usually have a strip of tint on the top, plus you get all nice new seals around it.
Edited by PM-R33
Just get a new one.
+1
Windscreen Service from Blue Mtns to the sea 1300369400
or Eddy Windscreens around Sydney 0414184584 or 95848504
otherwise the large commercial operations like O'Briens at higher prices due to their advertising costs
a mate who had his windscreen replaced in his 33 once told me that they are the same as a locally sold nissan, but i'm not sure which it is though. not sure if it was a 300zx or a r31 or something like that. either way it ended up only costing him about $200.
R33 and R34 windscreens are now locally made by PGI, so much cheaper than they used to be. My one was ~$300 and the guy came out to my house to do it.
PGI Glass
SKYLINE R33 2 DR COUPE 1993 - 1998 Catalogue number DN084 rrp $168
Edited by 666DAN
i paid around 400 i think - but one thing i did notice is on the replacement windscreen there is no little wire for front demister...
im not sure if nissan stock the ones with this or not though :domokun:
front demister?
do you mean the radio antenna like in an R32? I looked at a replacement windscreem for my old r32 gtst and it was about $300 for an aftermarket one (no inbuilt radio) or $800+ for a genuine one with the radio antenna wires.
I don't know what they were smoking but I rang Nissan for a price on a windscreen for my 32 GTST & they said there were two types available.
One was around $800 & one was a bit over $2000! No idea what it was that made it so expensive...
Then the guy who came to our shop to install windscreens quoted me $200 (no antenna) as he is good mates with the boss.
Ended up getting a dodgy roadworthy from the workshop next door to where I worked so never worrried.
Don't work there anymore. Should have got the $200 windscreen when I had the chance!
Do prefer the neat, inbuilt antenna but a mates S15 has a nice little antenna inside the car which you can hardly see.
Seems like the best option when the time comes
  • 1 year later...
+1
EDDY IS GOOD, BUT YOU SHOULD USE HIS TEACHER GLENN AT PLATINUM WINDSCREENS WHO HAS MORE THAN 25 YEARS EXP. CALL HIM ON 0419228163 HE IS NOT THE CHEAPEST BUT IS THE BEST!
Nothing wrong with a bit of self advertisement mate, but you should have been quicker! The op already had it done. Plus the third person speak isnt really necessary.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
