Is it recommended to change the block if your goal is around 400awkw, I want a healthy engine that is rock solid and wont break. Can the normal rb26 blocks handle this power healthy? without wearing it down.
And yes ofcourse meaning everything else is forged. and all the other mods are added the last thing is the Block, should it be kept standard or change it to an N1 block
Edited by GTRAAH
https://www.sau.com.au/forums/topic/324170-rb26-block-vs-rb26-n1-block/
In my opinion with 400kw it will be fine, just get it dipped and checked at a well known workshop get them to give you the ok before commencing work. Also depends on what combination you will be running.
Can I ask what mods you will be using?
Type B Tomei adjustable Cams ( Cant remember the measurments, but they are lumpy on idling)
Tomei Dump pipes
Sard 720cc injectors
Sard intank fuel pump
PFC
Z32 AFMS
Air pods
Garret -5 turbos
Fuel Regulator
Greddy Boost Controller 2 profec B
Oil - Air seperator catch Can
Xtreme Single plate Heavy Duty Clutch
Os Giken 5 gear set
Alluminium intercooler/turbo piping
Oil cooler
Spitfire coils
3.5 inch exhaust
600hp rated Cat convertor
So far what i have , ALl internals must be rebuilt forged. I Have not decided what yet
Unfortunately mate, it does come down to what internals are being used. Many packages/combination's will get you 400kw no problems but how long it will last is up to your selection of parts.
Tomei 2.8 is your best bet but expensive, but what gtr with 400kw isn't going to be...
Stock block will handle that, get it grout filled to the bottom of the welsh plugs to strengthen. It will help with the strength and harmonic vibrations. It is also meant to help with cooling. Wish I had gotten my block done when I had my motor built. Also make sure that you get a good harmonic balancer either Ross tuffbond or ATI
Standard block is fine, get good set of cams and plenty of head work... you'll need it for 400
Stock head will do over 400kw.
Mine is 455rwkw and no porting, another I know of has drop in cams and does 460awkw with stock ports.
Just add boost :laugh:
Just add boost :)
Hearing that warms my heart. Nice work. :laugh:
Where your engine doesn't breath as well, just add more pressure at a tangent to flow and ensure you're not choking it in other ways. LOL.
having seen plenty of cracked RB26 blocks I would personally be going for a N1 block if you are after a genuine 400awkw. either that or if on a budget try and get a early model (89 or early 90) R32 GTR block. They are slightly better than the later blocks but make sure it's in good health and at most on it's first oversize.
considering the cost of a new standard block vs a new N1 block it's no contest in my eyes.
@ beer Baron as these guys are saying
*dont machine out the boors too far, get the crank balanced to a high degree
*get it grout filled to the bottom of the welsh plugs to strengthen, get a good harmonic balancer either Ross tuffbond or ATI.
*get good set of cams and plenty of head work
Surely all this would make it more durable then an n1 block?
400rwkw from -5s is not going to be a cheap excercise - requires a switched on builder. You don't neccesarily need cams either.
Again, that same switched on builder will ALREADY know about how to fix the weaknesses in a RB block etc.
IMO if you use a decent workshop printing this thread out wont be required - given if you print it out and take it somewhere/someone who is less experienced - they will just nod their head and agree with you without really fully understanding what needs to be done/where/how etc.
Something to be mindful of.
Not a cheap excersise? Wuldnt it be cheaper then putting a to4z in ? I have cams already so i wouldnt need most of the stuff, All i need would be........... headwork, crank, pistons, rods, ALL THE WEAK BITS oil pans, oil resitrictors, n1 oil pump etc im looking 7grand MAX to get it done. Ive already spent around 20k on the rest of the shit. Incl labour. Do you know any good machiners? that know what there talking about for instance if i show them this thread
Edited by GTRAAH
    • Hello Liam - HA - somewhere in flies - possibly I have an update, but I have been so busy, projects have taken a back seat to getting business back on track.  I will let you know the outcome, but I think I am going to go for the 8HP,  CHEERS.  ELVIS
    • Thanks Joshuaho96, yes - as someone else also suggested, the 8HP seems the 'smart choice' - HA - and ZERO to do with cost, but I am sure 8 speeds will be better than 6 speeds - HA - maybe.  I will purchase a new 8HP,  Thanks.  ELVIS.
    • Nobody said anything about getting a "...cheap Falcon box..."- it was JUST a question about a specific transmission.  And YOU may have a problem with not enough $ - HA - I do NOT - so please keep your comments like you are some financial guru to yourself.  BUT - much appreciated re the cost of a new 8HP and I twill probably be the way I go.  Thanks.  ELVIS.
    • Most people I know in the BMW world are swapping 6HPs for 8HPs. The 6HP has a big issue with one of the clutch drum bushings wearing out shockingly early which leads to them going into limp mode going into 5th/6th gear as the oil pressure loss from the worn bushing causes clutch slip. Even with the adaptations in shifting the TCU can't bump line pressure enough to keep the clutches from slipping and burning. I've personally looked at a 335d with 6HP28 with one owner and ~90k miles on it and the transmission adaptations were way out of spec and even though it nominally drove ok I'm confident it would have needed a full rebuild sooner than later. Other than that they're fine, but the 8HP doesn't really have weird issues like this to my knowledge and they're in everything these days so pulling them out of crashed cars isn't too hard.
    • There is an ABS pump and a few solenoids. You could trigger the front/rear solenoids with a pressure bleeder attached with a Consult 2.
