Twoogle deserves a good sent off. Paul will be back at it shortly once the diff's fixed.. poor bloke worked so hard to get twoogle up and running after the first run.
Was nice to meet Charlie, Luke & Nathan today. They were working on twoogle all day. :P
It was a shame to not be able to see it run yesterday after all the hard work Paul put in to get it running again after the first pass drama. I'm sure if the diff problem was found earlier then that would have been another thing Paul and the guys would have fixed in the true never say die spirit of TWOOGLE :P
The perserverence, patience and effort will pay off soon :D
Good too see you again Johno :rant:
From What i have heard on the grape vine it is not power that is the problem but aparently it has found a whack more torque. Should run a no once sorted :P .
A combination of that and I think it was a very well prepped track yesterday (very sticky). A lot of cars were doing wheel stands and having troubles breaking traction to warm up the tires.
Was nice to meet you yesterday Charlie :D
Was in Sydney last weekend seeing Croyden about a 30/26 engine build and witnessed this car being run on the dyno. I must say this car is absolutely mental!! Paul then took the car out the front to the "private test track" for some 10,000rpm launches. Was the highlight of a very busy weekend and was unfortunate it didn't get down the track on Sunday.
Best of luck with it guys.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
