run in tune is: 300rwhp at 4500rpm-ish AN
only got a half tune coz it was overboosting. apparanttly torque/boost came on hard and was smokin the tyres on the dyno.
re tune after 1000ks, turn the boost up and rev to 6500-7200rpm see what she makes then.
in reality i really need a new yet another manifold + check what spring is in the wastegate
have vids duno how to put them up as they are mp4.
thing sounds like no other skyline i've heard
somethin like this
  • 3 weeks later...
  • 3 months later...
couldnt say, im assuming standard 32 gtst diff
in saying that, before the rb25det the car was originally an rb20de so wether it has a de diff or det or wether the de diff is even lsd i dont know. but its def an lsd
Edited by Char
Verrrrrrrrrrrrry interested in a vid of said sounds!!!!
Variety of vids would be sweet.
Hybrids are my fascination!
Edited by 045HOW
  • 1 month later...
Similar to my 30/25 with .63 3540 - just had Link installed and fired up for the first time 300hp (225awkw @ 8 -9 psi) - a few things to tidy up and then proper tune at 18psi in about 3 weeks or so.
for anyone interested this is the current tune, or HALF tune really
4th gear BP98 RON
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
