well there goes another R34. had a big accident on lancefield/romsey road when i was turning right, one car was turning and didnt see the other one behind him so i went and the rest was history, i got hit on the front side of the car and it spun a few times its totally destroyed. ill post up a pic soon. thank god the girl in the other car was fine because thats all i was caring about.
https://www.sau.com.au/forums/topic/325839-car-is-a-write-off/
  • Replies 50
Posted Images
Sorry to hear about the accident. Glad everyone's alright.
This accident sorta reminds me of the video question when going for your L's, where the motorbike comes from behind the truck at the intersection. Can never be too careful.
nah the intersection is further up when your coming out of Goonawarra. the first thing in my mind was the other person, i wouldnt be able to live with myself if she was injured badly and thank god she wasnt. ive got a very sore head and neck mainly because my head hit the side window. here is a pic:
woah big hit dude.... very lucky
yeah looking at the pic i know the one
thats the only good thing i can take out of that accident, but i definately would have preferred just to sell it though. im very lucky it hit me at the front because if i was a little more further ahead it would have hit my door and im sure i wouldnt be here right now.
Poor skyline :P. It looks like it was a daihatsu charade hit you (judging by the car on the tow truck). It always seems to be daihatsu charades in accidents....why is it that shitboxes always destroy nice cars.
The important thing is that your okay. And plus now you can buy back the wreck for a fraction of its real value and part it out and make yourself back some of the money you lost on the excess :P
that little daihatsu wasnt in the accident he was just a guy that stopped in his tow truck to give a hand, it was a subaru forrester that i hit, her car was down the other side of the embankment out of the photo on the right.
one thing id love to do is give a big shout out to the people that helped, a few of the guys helped direct traffic for a while they were fantastic.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
