hey
just bought a set of volk gtc's for my r33 gtr. got them home and realised i need a set of different nuts for them.
where am i able to find these specail nuts, and hub rings for them and is there anything else i may need to fit them?
thanks
https://www.sau.com.au/forums/topic/326042-gt-cs-on-a-gtr/
youll be the second silver 33r with gt-c's in adelaide then (havent seen any others yet). heres how dope theyll look once you get em on...
the standard volk nuts mine came with are 12x1.25mm internal hex drive nuts. youd probably be looking around the 250-300 mark for a set. on the other hand if you already have some nuts, see if a place like wheelworx can machine them down to correct diameter.
https://www.sau.com.au/forums/topic/326042-gt-cs-on-a-gtr/#findComment-5310872
The profile looks too high on the front..
https://www.sau.com.au/forums/topic/326042-gt-cs-on-a-gtr/#findComment-5311435
That's coz it is. Took that pic just after I put the coilovers in ans the backs were too low. Ideally I wouldve lowered the fronts to match but that would make it too impractical as a daily. Since that pic ice raised the rears so the stance is even now
https://www.sau.com.au/forums/topic/326042-gt-cs-on-a-gtr/#findComment-5311747
