RB25DET out of a GTS-4
no such animal. R33 GTS4 is NA. The RB25DET AWD comes out of a Stagea.
Simplest method, buy a GT-R - unfortunately you'll just have to put up with the RB26DETT.
Next easiest - buy a GTS4, drop in Stagea engine, upgrade brakes, wheels -> 5-stud
https://www.sau.com.au/forums/topic/326110-gts-t-to-gtr/#findComment-5311807
gayest thread
if u want a gtr u should have bought one. i hate flamin mongrels that make there cars imo gtr's they just look stupid.
whats wrong with an rb25 u can make them just as quick and even quicker than a gtr
https://www.sau.com.au/forums/topic/326110-gts-t-to-gtr/#findComment-5312446
hahaha wow lol didnt expect all this!
aha so im new to turbo cars kids i spose wat i ment was i was wondering if there is a way you can turn an rb25 into a twin turbo not really bothering with the AWD etc
anddddd i had no intention of chuckin a GTR sticker on haha i hate that aswell
i love that homo picture baha ta guys
https://www.sau.com.au/forums/topic/326110-gts-t-to-gtr/#findComment-5313421
I think there was a thread on it somewhere and the end result was something like not really worth it, strap a big turbo on your car currently and same effect...
You know, quite a few GTR's out there change their twin turbos to a big single.....
https://www.sau.com.au/forums/topic/326110-gts-t-to-gtr/#findComment-5313489
you can either twin turbo the rb25 or bolt in a rb26, but as was said above, there's not much point twin turboing the rb25 as a bigger single will do the same job. the only reason to twin turbo it would be for the wank factor so you can say to people "i have a twin turbo rb25. how cool am i?"
https://www.sau.com.au/forums/topic/326110-gts-t-to-gtr/#findComment-5313642
Putting in an rb26 would be far easier than trying to convert an rb25 to a twin turbo... but either option would be very expensive...
I think what you need to work out is, how much power you want?? Then from there you can look at the best ways to go about getting there... because a modified rb25 can produce a decent amount of power without needing to try convert it to twin turbo etc..
https://www.sau.com.au/forums/topic/326110-gts-t-to-gtr/#findComment-5316644
dont call us kids.
oh and just buy a GT-R, otherwise youll end up like a host of GTS-t owners wishing they did...
https://www.sau.com.au/forums/topic/326110-gts-t-to-gtr/#findComment-5318795
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
