Did the same conversion in mine but mines a r33 4 door but the rb26 was worked, forged pistons, acl bottom end bearings the works. I love it, i rekon its the best thing ive eva did to the car,i put a 34gtt gearbox in, lots of wheel spin and fun. :thumbsup:
For sure the rb26 is a great engine conversion for any Nissan I've seen them go in 260z's would have been nice if Nissan had made them 2.8 or 3l from the factory but they are still a great engine at 2.6
HKS V-Cam!
:thumbsup:
Got the car up and runing last night fixed the few issues it had and test drove it. Test drove very good even at 8-9 psi moves nice. Will get it on the dyno and tune it up
Nice, post up dyno chart when done.
Finally got the car onto the dyno only had enough time to get some prelim tuning done up to 10psi as the client wanted the car back so didnt get enough time to install the boost controller.
Here is a video of the car on the dyno, as i said earlier that we used the RB20 gearbox and as you can here in the video the 4th gear syncro is worn and has seen better days.
Enjoy some RB sounds on the dyno.
  • 3 weeks later...
The new E1280s from adaptronic is pretty sweet isnt it? even the old boxy version was pretty sweet for basic applications. The new one will probably replace the d-jetro PFC in our race car soon for a bit more R&D
Hey Trent
It's a nice bit of gear for the price far more advanced then a dejetro for a track car you have all the nice little features plus the ve tuning i started out with the e420c without ve then upgraded the firmware to ve and was much nicer.
Have you played with and mega squirts?? A mate of mine in qld swears by them the new ms3 has got some good features for a dirt cheap ecu the only downside you have to stick them together but a few place in the states put them together as a built unit.
Been playing around with your favourite ecu tonight pnp wolf v4 on a 33.
To be honest I Carnt go past nistune for any Nissan I really love to use them.
Ahh fair enough good excuse. Would like to get to the states one day check out the cars we are heaing to japan in October after Bathurst tho.
We are going to try do a full Vic season next yeah in the 31
  • Like 1
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
