forget the bleed valves they're hopeless and messy .... just take an empty coke bottle, cut the bottom off of it and lodge it firmly into the radiator opening. Poor coolant in and let the engine run for 10-20 minutes. You'll see a shitload of air come out as the coolan circulates through the engine and pushes the air out.
As for draining the old coolant ... just drain from the radiator or bottom hose (with car not running of course) ...dilute with demnieralized/distilled water as many times as you can until you see clear water coming out only. Then add your coolant concentrate.
too easy bro cheers
  • 10 months later...
OK I did a search on "radiator" and "bleed" and this was the most relevant thread.
I too am a bit confused about the procedure for bleeding the rb26 (in an R32 GTR - actually its an rb26/30, but anyway).
This thread looks to be talking about opening the bleed screw with a socket.
Based on the descriptions of where the bleed screw is, mine seems to be an allen head bolt (near a small gold sticker that says "never open while hot" - which is near the fuel pressure reg).
Maybe someone replaced it? anyway. My questions are:
1) Is my descrption of the bleed screw location right? Maybe I should post a picture?
2) what is the actual procedure for doing the bleeding? eg do you crack the bleed screw while the motor is cold and let it get up to temp, or will it push air out simply because the water pump is operating and the bleed screw is between the water pump and the thermostat? Or is it some other procedure?
3) how does one prevent coolant from pouring out the bleed screw and all over the engine bay?
4) any other hints?
4) any other hints?
1. Yes that's it. Mine is a hex head tho, directly above the gold sticker.
2. Cold stopped engine, fill radiator, open bleeder, wait until coolant comes out, close bleeder, top up radiator. I've never bothered to have it run at all, let alone warm it for bleeding.
3. Just be careful, you'll only get a slow flow and you stop it by replacing the bleed bolt. Its not a problem - you're over thinking it :)
4. Just be careful not to overtighten the bleeder and snap the bolt. BTDT.
So having your thermostat closed means no air will be trapped in the system? You need to run the engine while topping up coolant
Crack bleed screwFill radiator till you can't anymore, start engine and run, top up as needed, you will know when the thermostat is open as you will be able to see water flowing across the top of the radiator by looking in the fill point. It will be still water when the thermostat is closed and you'll see it moving when it's open. After this just keep topping up till there is steady water coming out of the bleed point (no bubbles)
Yeah you're probably right. Thermostats dont seal, but to clear any air pockets you'll want full flow. FWIW when i've re-checked after bleeding my way, there's only been a tiny bit more air, whereas when you first crack it after draining, there's a ton of air in there.
I bled mine doing pretty much everything above(bar the coke bottle). Let the car idle and warm up with bleeder open and lid off. Gave the pipes some squeezing to encourage any little trapped bubbles to come out. Also took it for a 20minute drive. Don't get scared but you can open the bleeder a tiny bit after a 15min drive. I did. Believe me the amount of air that came out was amazing before coolant came out. Under pressure and heat the air will travel to the highest point in the system(the bleeder) just crack it, literally one to two turns you will hear pssssst sound. Jiggle the screw and you will see bubbles of coolant seeping out. Just wait til you see abit more coolant come out.
Be cautious about this, if you take it too far you will get coolant shooting out and its f**king hot. Have a rag or towel handy and be cautious!!
I have a question of my own.
The first time I done my coolant, I heard like water in the cabin, I'm suspecting its water flowing through the heater core because it happened alot when revving. Its literally the sound of water flowing and sometimes taking a sharp turn it made the sound. Kind of like a half empty bottle in the car(there wasn't).
This is all gone after my second bleed, I think.
Another good point - putting the heater on full is also a good idea, especially if you're changing/flushing coolant.
i'll summarize the above point and advise on what i usually do as i seem to have work on these frequently now.
fill water, derr
stick a funnel or coke bottle or old radiator hose with enough tape around it so when you jam it into the radiator cap hole it seals without leaking, this must be higher than your bleed screw or there will still be air in the system.
fill your funnel up and bleed the air, remove the screw until only coolant comes out and replace it.
I usually start the engine, turn your heaters on flat out keep topping up the water as it takes it.
then drive around the block, just so the engine is to temperature and carefully do the same again, or you can get away without a funnel as there is pressure in the system that will push the air from the bleeder, but carefully, will be hot.
I have see people crack the head on their car from not bleeding the air from the system, no need worry too much, it really is a very basic principal.
i'm usually anal enough to re check it after a week or so also
hope this helps
  • 5 months later...
hey guys i have an rb30 with heating issues, she heats up while driving and cools while idle, i have just replaced the thermostat and have tried everything mentioned above to bleed the air out, i then took it for a drive and she still sits on about 3/4 temp the next thing i will try is to replace the radiator but only if i have to, any ideas be appreciated cheers.
it could be a blocked radiator but you you can create an artificial high point in your cooling system by running your car up on some car ramps ?
cheers will try that if the new radiator doesn't fix the prob, i discovered a hole in the old 1 and already having issues i thought i might as well replace it and try kill 2 birds with 1 stone, fingers crossed it will work, i am expecting it to arrive this week or nxt
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
