  • Replies 73
Recent update.
Just inspected another R33 gts-t today. The last one was stick, this one was auto. This time, I had the guy drive it for me and show me the car's response when boost kicks in. Being a cold and rainy day today, he drove around normal to warm it up a bit for about 5 min. After that, he switched the selector gear to "2" and went the way through with it. Being a stock car, boost kicked in at 3000rpm and it held on till around 5500rpm when he let go. ( was in a residential area, so can't boost it all the way.)
Though being auto, when he was driving it normal in 1st and 2nd gear, the car feels like absolutely normal like it should. It didn't have that weird draggy feeling the first one had. Some of the guys here suggested a bigger turbo being installed into the first car. Possible, but imo it shouldn't affect the performance below 3000rpm. The first car felt like it was towing a bus at 1st gear and this one feels totally alright. So back to the first car, I would suspect that something somewhere needs an eye on it and the owner is either hiding it or not knowing it. Feels like a clutch or gear slip, but can't confirm.
the vl isnt a p plate car :whoops:
Oh but it is.
Taken from the Vicroads website
From 6 July 2009, drivers issued with a probationary licence on or after 1 July 2007 may drive some lower performance turbocharged or supercharged vehicles. The definition of a lower performance turbocharged or supercharged vehicle is a vehicle with 6 cylinders or less that is:
  • turbocharged or supercharged with a power to weight ratio of less than 100kW per tonne
  • turbocharged or supercharged with a power to weight ratio between 100kW and 125kW per tonne and that is considered to be a family type vehicle (4 seats or more) rather than a sports type vehicle. A family type vehicle is a sedan, station wagon or hatch normally used to carry families/passengers with 4 or more seats and are equipped with child restraint anchorages. A family type vehicle does not include a sports car (two door coupe).
So a factory VL Turbo would be perfectly legal as its under 125kw per ton
Nothing wrong with a N/A if your on your Ps or using as a daily to and from work, both in which I do... its been great never had a problem even when I get pulled over on the way to work (happened a few times now) they come up look at the brakes and go.. "bugger non turbo"
lol they actually say bugger non turbo?
dont buy an auto gtst, resell value is crap, you are restricted in terms of mods and it will annoy you
the manual GTST it light years ahead and is worth every extra cent
please please please do not get an auto GTST
the auto GTST also runs less boost than the manual
this is why it doesnt feel as a quick
auto is 5 psi factory and manual is 7psi
that's pretty debateable from a speed aspect lolz.
HOONDAs are where it's at for the p platers
ahem... golf R32's. 3.2L V6 (well, it's almost an I6) hot hatch.
y'all nga's be living in the 1990's still. N/A p-plater friendly lightweight cars rocking AWD and massive torque in lightweight bodies have been readily available in the past 10 years. just that most p-platers can't afford that shit on maccas wages.
Lol @ 5psi. How would you even feel that? :bunny: My car was 13psi factory. CT20B FTW.
5 PSI on a larger turbo = 13PSI on a turbo the size of your wiener.
Recent update.
Whereabouts is the first car you drove? Perhaps finding someone with a bit of experience who is willing to give you a hand might help?
If it's anywhere between Hurstbridge and Burwood I'm happy to help out. I've been playing with cars for a long, long time and although have only been in my Skyline for 7 months, I'm pretty up to speed on where to look and what a good one should be like.
funkeh you missed out the high maintenence and purchase costs of the Golf (that and they are perceived as a bit of a fag/soccer mum car)
just give the habibs and muzzas about 10 years to catch up with the hot hatch trends sweeping across the world.
nga's need to drive a scirocco or abarth SS.
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
