Ohh ok sweet, my toyota had standard springs :whoops: and a tow-bar how do I know if it's a heavy duty tow bar?
Cheers
Prob won't be HD. FWD limits what you can tow. Prob 1200kg max so not legal. Might still do the job but the toyota won't like it much...
^^^^it does happen mate was in a car with car on trailer and went sliding on the freeway both cars luckily it stoped nothing flipped and no one crashed....
be careful and get some experience....
make sure trailer tires are set up good.(psi and good tread.) same as the car.
all four wheels are strapped down really tight.
FWD will tow ok. I towed my car from Winton back to Wantirna with my old Man's Honda Odyssey with a heavy ass rental trailer years ago. No issues at all.
Just make sure you have the car positioned on the trailer just forward of the trailer's centre point, as this will stop the trailer from getting it's sway on...
It all really comes down to what the car and the tow-bar are rated for towing. I know my SSS Pulsar (FWD) is only rated for 1200kg - so it'd be no good for towing my R34.
A big FWD like a Magna might be rated for it .. Toyota don't really make that big cars though, so I dunno - check out your Toyota's factory manual - should tell you what the towing capability is.
worth noting the towing capacity of that car as listed by Toyota is 1200kg
http://www.drive.com.au/used-cars/TOYOTA/V...291049&pt=1
(click specifications and look down for towing capacity)
remembering a average car trailer form a rental place is like 800-1000kg (sometimes more) add a car you are going to be close to doubling the tow capacity.
so if you tow and get pulled by the RTA/cops they can force you to leave the trailer on the side of the road.
Also if you have an accident...insurance will not pay out.
so will it do it..yes..will it do it legally no.
Meh, I dunno...
a) Breaking the law by towing over rated capacity
b) Running the risk of damage to the car, engine, transmission, tow-bar itself (who knows, it could just plain rip off at speed doing who knows what damage)
c) Voiding insurance (which if it flies off at speed and hits someone, you're gonna hate yourself for)
Is it really worth it?
Why does everybody have to get on the moral high ground all the time. We all know these things!
You guys worry way to much. Have you ever heard of people pulled over for towing to heavy a weight? Never.
If your towing to winton I would prob be a bit more sceptical expecially if you don't have a transmission cooler. I'd imagine you'll cook the tranny and possibly the engine might get hot. Thought it was going to be sandown. My wrong. I'd say the old girl is going to struggle. Don't you have mates with bigger cars you can borrow for a day.
Re pic above. A mate almost rolled his patrol with my boat on the back at xmas but that was because he didn't know what he was doing and hit the brakes when it started to sway on a downhill section (This is when trailers will sway most of the time) instead of accelerating out of it. We ended up in the dirt off the side of the road doing prob 80 semi sideways and then sideways squelling down the road. Didn't come around and hit us though. All he had to do was accel a bit and it would have been fine. I know heaps of people who have almost anded up in the shit towing cars on trailers. All due to swaying with lucky endings like my mate.
Point being you need to know what your doing and weigh the towbar right as one of the guys said above. Boat is a bit light on the towbar and it sways on other mates cars. The gtr with 18's tows it fine. Its only about 1000kg inc trailer that almost rolled a patrol.
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
