Hey all those people from NSW im new to the forum and from NSW, thought this was the right spot to post an introduction. Well yeah im still on my L's at the moment and ive been learning on my older brothers R32 Skyline. Have fallen in love with it and am currently searching for either a R33 Or R32 stock non-turbo for while im on my P's. Although i dont have a cash at the moment im really looking forward to owning my own.
After helping my brother rebuild his RB20 motor over many long nights, i've learnt a lot and am looking for somewhere to learn abit more about my Skylines and more about the RB motor series.
So hopefully i can learn a thing or 2 here :P
Cya guys.
https://www.sau.com.au/forums/topic/327336-introducing-myself/
Hey Dude!
Welcome to SAU :P
I'm in the same boat as you but I, just picked up my Skyrine its a N/A R33 RB25DE it's an awsome car, Dont listen to anyone if they give you crap of owning a N/A Skyline...
Justin!
Agreed :). most people who has seen mycar loves my car(N/A R34) :D
Buy an r31 for your first, reliable, got enough go for an early p plater, cheap enough so when you crash it within 6 months it's not the end of the world. Save up for a 33 or 32 for when your off your ps
but that's just my opinion anyway,
welcome to the club, good bunch of people on here
thanks for the warm welcome guys. :)
and sorry star32 couldnt find the right section.
and dont worry juz im not stupid with money and parts. Genuine is the way to go.
and good info SHM17Y. But ive learnt on a 32 Turbo and i absolutely love it. and i love the look of 33 and 32. so i dont think there is much changing my mind but thankyou for the idea. hehehe and plus there are some pritty awesome 31's out there :P
Hey Dude!
Welcome to SAU :)
Justin!
That's a really car you've got there too Justin :P
Welcome aboard Lucas :P . Join SAUNSW when you get the chance too eh?
Here we go Lucas...
http://www.hgeconsulting.com.au/membershipform.pdf
Fill out essentially, Q 1-9 (10 is optional) & send it off to that ACT address with fees.
Get discounts on tyres and special deals at events.
Look forward to seeing you with your new wheels too. :)
Here we go Lucas...
mate might need to hold that off abit. Gotta get some cash together to buy my car first :P
Here we go Lucas...
Look forward to seeing you with your new wheels too. :bunny:
Also get access to the coolest part of the interwebs
N/A R34 FTW on your P's - goes a little harder then the 33's and 32's *flame jacket on* :bunny:
Welcome man...if you buy a skyline on your p's its the best car to have as a first car...so much fun.. and you learn so much as far as driving is concerned...as long as your not an idiot and rap yourself around a tree or be a hero and lose your licence at every set of traffic lights :D
GL!
  • 1 month later...
rb25 r32 - they are rare but would go better than a r34 neo because of the weight but you'd need to find one in manual - i think most of them are auto.
Thought id jsut update this thread. Ive had a look at many R32's, but not many R33's and one of my wrecker mates managed to get me a RB25 turbo for cheap as. So im gonna drop it in the futuree car. And convert it to a NA. :)
Engine conversions are classed as a Performance Modification, this would be illegal whether it be NA or Turbo. And since the RTA will have the engine number marked as a Turbo also, it's going to cause more problems.
Keep the motor standard and do suspension mods.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
