  • Replies 41
Don't later the meet time >.< We chill out talking so it's not as if it's going to matter being there earlier.
Spotted some randoms loitering the carwash tonight >.>
Am meant to see a film on this dude: banksy-flower-riot.gif but might be able to make it anyway, we'll see!
Make sure you see this before it closes. It raises more questions on Banksy then it answers though.
good turnout if it was any other night would have definately come for a drive after just had places to be.
oh and thanks to whoever lent me the screwdriver! :)
man my car needs coilpacks... hurry up nengun sheesh... :)
Wow so tired. My eyes hurt LOL.
Hope all is ok with Niroj?
And everyone made it home safe, sounds like we went the right way given the popo on princes.
Sooooo nice to see/meet everyone and some very nice cars, those gtrs are the sex. :)
Thanks all for an awesome night, and thanks heaps for waiting for us. See you all on the next one.
all good guys. just got home. car is perfectly fine if a little muddy. thanks to all those who stopped and helped. apologies to y'all for the scare. to top it all off i got a flat on the way home and had to wait for an hour for my mates to find me. i knew i shouldn't have washed it
Was good to see a couple of familiar faces again, haven't been on a cruise in far too long... Thanks Danielle for letting me ride shotgun.
Niroj - Can't believe how lucky you were not to do any damage to yourself or your car.. So close.
Thanks again to all for waiting for us :)
Edited by Dr_Drift
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
