I had a good look underneath the car today just to check for any problems and came across evidence of a small leak.
I'm unsure if this is a common thing on the M35's but just looking if anyone can help give me an idea where this leak is coming from.
From what I can see, it looks like it might be coming from loose hose clip.
The leak doesn't seem major, and there's no drips under the car overnight so far.
Looking at sorting out the leak, if anyone has any idea or can help, your input would be appreciated :)
https://www.sau.com.au/forums/topic/328637-help-with-leak-under-nm35/
Small leak? :down:
It could be a few things, most likely the rear of the passenger side rocker cover, they are well known to leak from there. Fixed with a replacement rocker gasket.
It could also be one of the plug hole seals, mine had completely filled the rear plug and spilt out under acceleration. Fixed with a smear of silicone.
Hopefully it isn't the oil inlet for the turbo, its a pain to get at. Can you see oil weeping from the top? See if you can get the camera in there.
Thanks Scott.
I've inspected the rest of the engine bay as much as i can but couldn't trace it any further than that clip and where the arrows are.
I can't see anywhere else where the leak is coming from besides this part.
It doesn't seem to be leaking much (as in there are no visible drops on the ground yet). The car should still be fine to drive for now, right?
Hey Dimi, you picked it up last week so it's still under warranty. Take it back and ask them nicely if they can rectify the problem? You didn't pay for a car with an oil leak so they should have no problem fixing it for you.
Hey fellas, appreciate all your help! :)
I think it is engine oil.
You might be right though. They might have fixed the leak already because it doesn't seem to be dripping at all.
So what i'll do is degrease it and sus it out after a good 100kms worth of driving. If the leak persists, i'll contact the dealer and ask them if they could rectify it. They should be cool about fixing up the leak, right?
I might give them a call today at lunch and ask them if they sorted out or noticed a leak before.
Edited by dimi108
Okay, so i degreased everything and took it for a good 100km drive.
I can now see more clearly where the leak is coming from.
The leak is there and i can smell it when the car is at idle with the fan on.
It's at this odd location just on top of the turbo.
What are your recommendations on this? Take it back to the dealer and ask them to help me rectify the leak? I've only had the car for 7 days.
Edited by dimi108
My car is leaking slowly from the same spot, it is the rubber rocker gasket by the looks of it. They will probably order one in and fix it, you could of course get it yourself and fit it if the dealer isn't local.
I would change the plugs while you're there if they haven't been done already.
Yours is doing the same thing?
I see. Well at least i now know it's not an "impossible fix".
It seems like a slow leak on mine too.
How long has yours been leaking for Scott?
Edited by dimi108
this
pretty sure they have to fix it under the statutory warranty that you get from a dealer - 1 month and 5000(?) kms i think
How it passed a roadworthy with that much oil underneath, I have no idea.
I fixed mine myself as I didn't want the dealer touching anything else on the car... I should have bought a new seal though, instead I used silicone and it only lasted a few months.
Thanks fellas. I called them and they were nice about it. I'm going to go there this afternoon to have a chat then i'll leave the car with them on Sunday afternoon. Hopefully it doesn't take long to repair.
    • I was using the wiring diagram I have So 12.74V is coming into the rear Fuel Pump relay as I measured.  When I turn the key to ON im getting 0.6V to the Fuel Pump plug; which i assume is backfeed voltage and doesnt include the 12V from ignition power.  The rear relay is working and being triggered.  From the diagram I clearly see the rear relay 80 = Rear Relay going into the Body/H loom (R-27) 27 = Fuel Pump plug going into the Body/H loom (T-20) 40 = Short Connector (R-27) I'm reading 12.74V on the blue/black wire which is the power for the Fuel Pump   From this diagram I can see the Ignition relay goes into the front and up to the ignition  2 = Fuel Pump Relay <1M> (R-27) 37 = ING Relay <1M> I started from the pump using this reference Which the way I read it (referencing Nissan wiring color codes) is: Pin Wire Color Function 1 B/P (Black/Pink) Ground 2 L/W (Blue/White)        ECU Trigger 3 SB (Sky Blue) Fuel Pump 5 L/B (Blue/Black) 12V Constant Tested SB to SB on Fuel Pump for continuity - confirmed Tested negative on Fuel Pump to 12V battery and L/B - confirmed 12V Pulled the relay putting 12V between Pin 1 & 2 and testing continuity on Pin 3 & 4 - confirmed relay   So that has me looking at this part of the circuit to understand whats happening here...and im still confused. From best I can tell; the disconnect is back to my previous diagram; between Ignition Relay and Fuel Pump Relay...which yet again; afaik is where the immobiliser should.    Thats what I was trying to explain to GTSboy; im not trying to fix it myself; yet I seem to have to get a Masters in Electrical Engineering (while im busy doing my actual job of DevOps & Cloud Engineering) somehow.  I just wanted more expert opinions; or more so that what I tested is correct and proves it to something around that area; to go back to the alarm tech (for a 3rd time) that he needs to fix it. He keeps telling me its not the alarm. He lives on the complete other side of the city so i understand not wanting to make a trip but as I said before if its the alarm it should be up to him to fix it. But he's adament its not; even though I pointed out the FP was immobilised through the original alarm. To my mind; it seems that the ECU is sending the signal; but the ignition is not getting 12V down the line.
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
