PM replied.
Sorry to the guys who asked for parts today and yesterday, i've been having some problems. Parts will be express posted tomorrow instead of normal post they they should arrive even earlier.
  • Replies 56
Each of the pedals are separate. I've only got the clutch pedal, not the whole box.
I could do the pedal for $40 posted.
Bugga, really only need the box.
hey neil, do you still have the front n rear brakes (the entire thing, discs, calipers, and the arms n stuff) basically everything I need to convert from 4 stud to 5 stud?
yes i believe i do if you're doing it on a non-turbo r32 (or 33 i think). i have all the control arms, hubs, rear drum handbrakes and cable, etc. PM me with an offer and we'd have to arrange transport via freight company.
hey, can you give me some more info on the coil overs?
you said you don't know if they are height adjustable or not, can you have a look, and see if they have thread running up the inside under the coil, and if they don't do you know how low the car that they were on sat? also what cond and what price do you want shipped to sydney.
They don't have the thread up inside the coil so i'd say not height adjustable. The car had deep dish wheels that were sold before i bought it and i stripped it down straight away so never saw it with wheels, but someone else who inspected the car before me said it sat quite low. The car had fmic, wheels and some other mods so my logic says i think he would have had lowered suspension on it too.
I can't see any signs of leakage from it (no oil anywhere, shock shiny bit is very clean). I'm only after $180 +postage because i can't guarantee what they are. That's coilovers for less than stockies :)
mindflux- i had a try this morning but didn't have anyone to help so the cradle just turned when i tried to crack the nut. will have someone to help me thurs or fri.
Pekatu- i think postage would be about $30-40. i could do them for $210 posted and i'll pay any extra.
msky- boost tee is in great condition. i just bought a ebc off Merli so no need for this anymore. postage would be about $4 and that would be overnight.
hey buddy, is the rear the 4 door seat setup? Im after the upright seat with the fold down centre section.. if you do have it, i will give you 50 for it. If it fits into the 2 door version. Thanks.
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
