That would be great as i pick my m35 up on wednesday. If you get them is there anywhere in brisane / capalaba area that does the install?
You can easily do it yourself if you follow the info on the forum. There's an install guide and wiring diagram that Simon has put together in another thread here http://www.skylinesaustralia.com/forums/St...ig-t203961.html
Otherwise any audio/alarm type installer could do it for you at a price. Just print out the info & take it along to a few local shops & see what they say.
  • Replies 76
Posted Images
I just bought the last one from Chook a week or so ago. When I found out he had none left I thought I'd ask my "buyer" in China to hunt me down a price on 10-20 of these so I can supply them to forum members at a good price.
Give me a week or two to see if I can get the HR3's in at a good price for you.
that'd be rocking.. and wouldnt have to justify it to the mrs.. she already wants it :worship:
see also Zylux. same unit. seems there are 3-4 people bringing them in under differnt names.
btw: globalsources or alibaba are your friend. the MOQ will probably stuff most people though.
It seems Zylux in Australia don't have any to sell right now, unless I'm looking at the wrong url. The info is there (not quite the same specs as the ASUKA HR3 - no USB - but close) however I can't find it in their online shop.
You are right about minimum order quantities. But my buyer seems to get around this by buying sample amounts - for muliple customers...
Most of the gear I import for my business normally arrives costing me 25% of what I can buy it for here in Aus (yep, save 75%) so I'm confident if he can get it to me then a bargain is to be had by all.
  • 5 weeks later...
Any body have any tuners left available?
How much?
worth it?
Hi Aaron
I just tested a sample tuner last night. It's sort of an alternative to the Asuka HR3.
What it doesn't have (although the manual says it should) is an AV input for reverse camera. Not a prob for me as I have a reverse cam input on my Eclipse head unit. It also doesn't have 3 x AV outputs for you to run to other screens with AV inputs.
What it does have:
1 x AV output (coax vid L & R audio)
1 x Component output (RGB)
1 x HDMI output
This means it has flexibility as to what you can connect with. All of these work at same time so you can run another screen as long as it has the input to suit, or you get a cable that is (say) HDMI to AV.
Diversity (dual) f-type antenna inputs
Powered antennas, which are optional extra with other tuners (V series owners need these), come standard with this one. They work really well at my place which has crap TV reception. I received nothing unpowered, but with 12V applied the channels came in really well (indoors with steel frame house). The factory Stagea antennas are supposedly better again.
USB for playing video / audio files and recording live TV (tested and it works great, but not sure how often you would want to do this though).
And mounting brackets (Asuka doesn't come with these.)
So for what looks to be about $230 delivered to your door (add another $10-$15 for a good quality AV lead) and an arvo of your time you get TV in your car. I reckon it's worth it :bunny:
I'm still not sure if I'm going to bring in a batch of the Asuka HR3's, just for those that want a reverse camera input (& maybe extra AV outputs for other displays) since these new ones look to be the goods.
Equivalent cost of the Asuka (if you needed aftermarket antennas) would be close to $370 at your door....
Anyway, I'm going to install my sample tuner in the car this weekend and test it for a few days. If it continues to impress I'll have a box of these available in a few weeks, just in time for Christmas presents.
Cheers, Leon.
Hi Aaron
What it does have:
1 x HDMI output
Cheers, Leon.
Im in! 100% sure. not fussed about the reverse camera, for some reason I hate them and wouldnt've installed it if it came with one, dont ask its just a personal preference.
the 3x AV output isnt a problem. If I was going to do headrest for example. an AV splitter will do the job.
does it have an AV and/or HDMI input? Lets say I wanna hook up the PS3 to it. when i install a transformed powerpoint.
Like I said, I'm definately interested, as the cheapest i could find $510 for the HRIII replica, which is not so much a replica.
Let me know the earliest you can get these in, and i will Transfer the dosh to you.
Cheers.
Cheers.
No worries, you will be nearly the first to hear!.
They only have 2 "inputs" as such. 1 is the RF tv signal via the f-type coax connectors & the other is the USB port for play vid/audio files. They show one AV input in the manual but it is actually an output & is labelled as such on the case.
If you wanted to set up a PS3, I would say get the AV splitter/video switch device you mentioned but find one to do all the connections you need. ie TV or PS3 in (switchable?), muliple outputs for head rest screens.
I say you can never have too much entertainment in your car, especially if you cart around young'uns :bunny:
I say you can never have too much entertainment in your car, especially if you cart around young'uns :(
lol im only 20 no youngins for me.. entertainment is for myself.
im looking forward to the digit receiver
what channels do you get throught it??
Sounds good.
So this won't affect the displays normal function apart from reverse camera?
A bit foggy myself
Hi Graham. No it just replaces the TV function with a TV tuner that picks up regular digital TV broadcasts. Plus you can play movies or audio files from a USB stick. All the other functions like trip, fuel consumption, compass etc remain as they were. If you don't have a reverse camera & wanted one, then the Asuka is a better model 'cause you can integrate both functions. I wasn't looking forward to putting a rev cam on my wifes car anyway as it looks to be a bugger getting the cable down the tailgate. Might just stick with TV for now.
Aaron, whatever can be picked up in the area you are in, ie tuned like you would a regular TV, should be able to be received whilst "parked" in your car :)
Cheers, Leon.
well done Leon......great work!
P.S. Your in Coff's Harbour aye? If so will have to meet up next time I go up......my wife's parents have a large farm up there!
Edited by Jetwreck
Hey Jetwreck, thanks but all the work was done previously by Chook, Andy, Brad (and others?). I'm just helping out with sourcing more tuners. I'm bummed that Asuka are so hard to deal with. Price keeps going up (from what I hear) and service is coming down. It's a shame 'cause the product was really good.
Having said that, this sample I've been testing continues to impress. Especially for our V series brothers who need the external antennas as these come standard.
Seeing as it will be delivered for about $230 makes it great value. Andy mentioned there's a way of connecting a reverse cam to the existing tuner box so I guess it doesn't matter if the new type can't perform that function. It's funny when dealing with these cars. Just when you think there's nothing you can do, along comes 3 ways of doing it :ermm:
BTW, I actually live between Byron Bay and Ballina, so about 2 hours north of Coffs. I do a lot of work in Coffs and Port Macquarie though, so you never know. I may be passing through while you are there.
Cheers, Leon.
PS Did you get a chance to look at your OBD2 connector to see if you had a wire in pin 14? Mine's been removed and I suspect that's why my new info meter doesn't work..
http://www.skylinesaustralia.com/forums/in...t&p=5548993
ffs......why did I have Coff's in my head this morning.....I meant Byron Bay! :P
Well that's easy then! If you're coming up to Byron then let me know. We can grab a beer :ermm:
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
