Haha yep sold it Tuesday night and bought this Wednesday night, couldn't of worked out any better!
n u on ur red ps....with those plates too on, i would say be careful man...also congrats on your new car :D cant wait to see it
All good I know it's cop bait but I wouldn't of gotten it if I didn't get the exemption, not concerned so much about cops though just insurance and they've said it's all good as long as Vicroads says so. Am loving it more and more everyday, lots of kinks to sort out engine wise though...
All good guys I've learnt my lesson with my first car the VLT, tried to do a loophole in the law and cop's let me off (Insurance was another story), got written off and found not at fault but scared the bajeezus out of me, now I have a work exemption to drive this so insurance is fine with that. Absolutely in love with this car I don't even care about the power it's just the sound for me I think, I've missed intercooled turbo's thats for sure :P Can't wait for a track day! I think what they say is right though you don't really learn until it happens to you or someone close to you, I came close enough for me to re-consider how I drive every second of every day.
Edit: Have realised it's almost a twin of PM-R33 without the carbon mods and such he has.
just curious too know how you were granted an exemption on such a 'typical hoon car' with those modicfications, plates etc...
My understanding was that for a work exemption, something like a v8 ute would in some cases be approved for a job that involves heavy loads etc..
i was rollin in the 32 with a work exemption...
Hook me up with your advans miguelone
They look alright in the photos but really they're in pretty poor condition. Huge guter rash, polished lip is all pitted & they have a bit of paint bubbling from corrosion on the spokes. Still they only cost me $200 though.
There was a set on eBay in the exact same sizes as mine(17x8 +35 17x9 +38) last week but it looks like they're gone now.
Will give you $201 for them :P
*discreet point to my sig@ both dylaan and miguelone*
:D
I'm kicking myself because I know of someone who sold a set with tyres for $400. I'll let you know if I want them when I get my tax money back
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
