yeh.. i think its set to 5500 or 6000 standard..the 8MR's launch is set to 5000rpm
but you can bring it back to whatever.. car launches good at 4500-5000rpm drops, so might set it to that..has lots of interesting gadgets in the ecu.
i think its done through some "tephra" thing?
anyway, theres a guy getting around by the name of Burnzy, who is well known for tuning evo's around here, said he'd delete speed cut and a few other immediate improvements for $50..
e7 has launch control?
Haha so you did go to Burnzy
Yeah just need a quick flash to get launch control, however if you do tephra mods remove put a decat otherwise it'll make one of your standard one :P
After you go to him a few times he won't charge for things like launch control etc to change etc
Yeh meeting up with the lad on Sunday. I haven't really spoken to him about it, just wanted speed cut gone, but afte looking into it, there's a few things that can be done.
Full tune $350 can't get better than that!
Burnzy only charges $350 for a tune? Hope he's still going when I eventually get mine bahahah.
dunno exactly, all I know he came back and told me that it's making 233awkw and less than what a dyno reads
And he is usually pretty good with the results as people get their tunes from him, get a power figure and when there is a dyno day make more power than he has told them
So what ever he was doing it worked
Yeah never asked myself, I just said do what you have to do and that's it, because he asks if you want to ride in the car while he is tuning it
lol sounds fun... or scary :P
but yeah have heard a lot of good things on evooz.
alvin lol at this rate looks like sau team evo will be really happening lmao xD
Edited by kaitoukid
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
