Wow, very nice cressida. I reckon the first rims tbh, they make the car look more classy to me. The second ones give it a sporty look, but i honestly think the classy look, looks alot better on that car.
Which ones are the enkei's?
thanks mate...:D
The enkeis are the 5 spokes...they are better wheels, but I agree the other ones suit its style better..just a pity they are shit rims and need refurbishing....oh well..another thing to add to my to-do list :/
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
