  • Replies 50
My understanding is that the atessa sends 5% drive to the front wheels as a minimum at at all times.
Regarding fluids when my car was auto I bought 20L of quality synthetic atf and used it in the auto, the atessa and the power steering.
Well just as abit of of an update with my car, took it to a GTR doctor xD, got all the fluids in the car changed, $600+ of fluids! Both diffs, transfer case, gearbox, ATTESA actuator.. everything done except a coolant flush which is getting done next time i'm there.
My mechanic belives that it is most likely a G sensor. However upon driving he believes that there is something abit wrong with the speedo.. When accelerating it stays on 0kph then quickly rises to say 40kph, the delay is minimal however he belives that this could also cause my issue. As the ATTESA takes inputs from the G sensors, speedo etc right? So if there is a delay, the ATTESSA might be tricked into believeing there is wheelspin.
Any chance of this being the cause? I plan to get it looked at again in the near future!
Looking at the R32 RB26DETT System Figure, the ECCS unit gets its' vehicle speed signal from the speedo which gets it from the gearbox.
I can't find a diagram for the R32 ABS/ETS unit but I would imagine that the system is only looking at differential readings from the ABS sensors.. will have a look when I get home.
Edited by bubba
Yeah it looks like the ECU gets the vehicle speed from the speedo (for speed limiter etc) but it also looks like the ECU only supplies the ETS (attessa) with throttle signal and engine RPM, I guess the ABS sensors would be providing the speed for the ETS computer. If you end up needing another speedo with speed sensor let me know, i've a spare.
Roger that doo doo!
Is it possible to repair the speedo without changing the cluster.. as i believe my car has genuine k's and would like to keep the "standard" ODO on there if possible.
If it is something as simple as this to fix my problem that would be a massive relief!
I had pulsing issue where if the car was cruising around 100km, I could feel the car surging forward slightly every 5 secs or so constantly
at the time if didnt put 2 n 2 together as I was only fixing the flicking needle but it also sorted out the surge as well
Hm my issue occurs at 100kph as well, not sure if mine "surges" .. the torque just goes foward after a certain amount of time.
I will have to get this fixed asap and see if it solves my problem:D
The 'speed warning' unit which looks like a fuse is interchangeable between speedos so you can keep your original cluster. Still don't know if it supplies speed info for ECU or if it's just a limiter warning or power steering/hicas input. If it's jiggered it might be doing something funny to your attessa at 100kph, but check the speedo cable first. After the G sensor of course
are you 100% sure the tyres are all the same???
do a liltle test, put the tyres on the front on the back and back on the front, than go for a drive and see if it is the same.... if it dose than its a prob with the 4wd system, theres a test you can also do its in the workshop manaul mite be worth alook
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
    • I believe @Duncan has given it a crack at Mt Buller before (in actual race conditions)
