  • Replies 50
My understanding is that the atessa sends 5% drive to the front wheels as a minimum at at all times.
Regarding fluids when my car was auto I bought 20L of quality synthetic atf and used it in the auto, the atessa and the power steering.
Well just as abit of of an update with my car, took it to a GTR doctor xD, got all the fluids in the car changed, $600+ of fluids! Both diffs, transfer case, gearbox, ATTESA actuator.. everything done except a coolant flush which is getting done next time i'm there.
My mechanic belives that it is most likely a G sensor. However upon driving he believes that there is something abit wrong with the speedo.. When accelerating it stays on 0kph then quickly rises to say 40kph, the delay is minimal however he belives that this could also cause my issue. As the ATTESA takes inputs from the G sensors, speedo etc right? So if there is a delay, the ATTESSA might be tricked into believeing there is wheelspin.
Any chance of this being the cause? I plan to get it looked at again in the near future!
Looking at the R32 RB26DETT System Figure, the ECCS unit gets its' vehicle speed signal from the speedo which gets it from the gearbox.
I can't find a diagram for the R32 ABS/ETS unit but I would imagine that the system is only looking at differential readings from the ABS sensors.. will have a look when I get home.
Edited by bubba
Yeah it looks like the ECU gets the vehicle speed from the speedo (for speed limiter etc) but it also looks like the ECU only supplies the ETS (attessa) with throttle signal and engine RPM, I guess the ABS sensors would be providing the speed for the ETS computer. If you end up needing another speedo with speed sensor let me know, i've a spare.
Roger that doo doo!
Is it possible to repair the speedo without changing the cluster.. as i believe my car has genuine k's and would like to keep the "standard" ODO on there if possible.
If it is something as simple as this to fix my problem that would be a massive relief!
I had pulsing issue where if the car was cruising around 100km, I could feel the car surging forward slightly every 5 secs or so constantly
at the time if didnt put 2 n 2 together as I was only fixing the flicking needle but it also sorted out the surge as well
Hm my issue occurs at 100kph as well, not sure if mine "surges" .. the torque just goes foward after a certain amount of time.
I will have to get this fixed asap and see if it solves my problem:D
The 'speed warning' unit which looks like a fuse is interchangeable between speedos so you can keep your original cluster. Still don't know if it supplies speed info for ECU or if it's just a limiter warning or power steering/hicas input. If it's jiggered it might be doing something funny to your attessa at 100kph, but check the speedo cable first. After the G sensor of course
are you 100% sure the tyres are all the same???
do a liltle test, put the tyres on the front on the back and back on the front, than go for a drive and see if it is the same.... if it dose than its a prob with the 4wd system, theres a test you can also do its in the workshop manaul mite be worth alook
    • Didnt realise RB's had more then 1 head.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
