  • Replies 45
Welcome to the forums :down: nurr nurr Charlie! 21yr old female R34 owners are spawning everywhereeeeeeeee :)
PS HI!
I know lol.. we even have similar names!!! (Mine's Charlotte) *que x-files music*
Hi Everyone
Charlotte- Yay nice to meet another female owner, I haven't seen any other female owners so far, but I'm from Bendigo.
To everyone who LOLed at the title- Big emphasis on the age and and gender, I figured that would get a few people's attention, so people would comment so I could meet everyone.
Specs, Colour & Mods:
Specs: I can't find anything online much about the 25GT's pretty much everything I find is on the GT-T or the GTR's. I have the non turbo model because I'm on my green P's otherwise I probably would have gone for a turbo model. Redbook is pretty slack on specs as well, except for telling me that it is 17cms wider then a 1994 BMW 318I.
My car is totally stock at the moment, was previously owned by an Asian guy who had it imported, 120,000 KM's. 2.5 Lt engine (it's a 25 GT)
Colour: Metallic Silver
Interior: Grey Plastic with 2 tone Grey cloth interior
Rims: Stockies
Trans: Tip Automatic
Photos: None at the moment, I'll post some in the next few weeks.
Mods:
No mods so far (I've only had the car for 1 1/2 days) unles taking it to the car wash counts to remove the layers of grime and dirt (car was very dirty when I brought it, so I used it to get the price down) my car is in desperate need of a detailing, it's had no external love for quite a while but I have a few things planned. I had the car transferred into my name today, and now have slimline plates that are ***088 (my year of birth)
FUTURE MODS: I can't do anything to much to it, so all mods will be cosmetic because the cops are pretty bad in Bendigo and already stare at the P plate when I drive past....on the speed limit.
* Exterior Detailing, giving it a bit of TLC
*Sound System
* Hasn't got a rear spoiler at the moment so I'll be getting one of those
*Possibly a body kit
*Maybe silver dial rings
*Thinking about taking the sound matting from under the bonnet as it's a little hacked, and could do with a little more noise
* possibly a cannon if I can get away with it
*Mags
That's about as far as I've got in my thinking as of yet, would like to hear any other suggestions from you guys.
if you want it detailed by the best, take it to Final Inspection - www.finalinspection.com.au
you might find the cannon gets..... annoying and if you're worried about cops you might find a cannon is like dialing 000, they might not come straight away, but they'll get to your car eventually.
nice set of rims, lower it a touch and just keep it looking clean and tidy :)
Welcome Chantalle,
Always great to see another R34 lover :D
I've only had the car for a couple of days now but I'm liking it lots so far, except the out dated light grey around the shifter, needs more black less grey.
Although I'm unsure what the "Snow" setting is? is that like some sort of traction control?? (Haven't been able to find an answer online)
Assuming it was a 20DET auto Ceffy, even then, he'd have to have a heavy foot wouldn't he ?
That switch went bonkers in mine, stayed in second even when switch was on POWER, wouldn't use fourth, then intermittently would use first on decel, made corners unpredictable.
Thanks for the explanation guys. That might have come in handy over the last 2 days. I drove my car home from Melbourne on Tuesday night, Wednesday morning went to collect the mail and put my foot down (not heaps) without thinking (RWD+Heavy Rain= Spin)and was shocked (I've been driving FWD's now for the last 3 months while waiting for my BMW to be fixed)
he went from driving a camry to a 20DET so he had to learn about finer throttle control still. Also skinny stock tyres didn't help.
Yeah I remember how much I was freaking out when I first drove my r34 in the wet, gave to the beans on a straight stretch of road and had the back kick out on me. :( haha
That's most of the fun part of owning a skyline :P
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
