Mate, you are truly a champion for trying out all those turbos. I sincerely hope one of them is perfectly suited to your car! Will keep an eye out on this!
Also don't be frightened to post the results at NS.Com in the Motorsport section - even though it is an RB. I am sure some handy information may be taken in the way the different turbos perform on the same 2.0 engine.
runing water cooling??
Thats the plan. Will start bolting all the fluff on early-mid Feb when Fatz gets his CS's off my car and it gets back to Melb. Waiting for th ebillet turbz...will post pics of it side by side with the TD06-20G and the TD05, T67 and 25G next week
Hey Pete. People sometimes dont bother with running water cooling saying "some turbos only run oil so all is good." But the way I think about it is that the bearing materials, housing design and materials are all designed and selected on the assumption that coolant/water is going to keep the ultimate temperature lower. So if you run them without you may end up with premature bearing failure as a result of running hotter then normal.
Roy, I think its more applicable to ball-bearing. The main problem with the oil only cooling is the premature engine turn off, when temps are high enough to cook the oil inside the cartridge. All the resudue and burnt oil substance will block the passages and do damage to bearings. 10degrees working tempreature difference won't be that noticable compared to shut down without cool down. They would design and choose materials with a lot of stress in mind, including water cooling system damage. On the dayly car or a public transport that would be considerable. But on a modified vehicle. I don't think so.
Just my 2c.
Just run a separate little reservoir with a bilge pump that cycles clean water through the turbo. Put a little open/shut valve on the reservoir and you can make everyone cups of tea after you have done a few hot laps. Simple and effective.
fatz, dont be a hack. I have grabbed a bunch of these so that i can easily change turbos etc without having to dick around with coolant lines going to awkward spots, ditto oil supply line.
http://www.staubli.com/en/connectors/market-solutions/motorsports/dry-break-coupling-sphba/
Just need to work out whether I have enough space for wiggin/racetech clamps on the turbo outlet and make some v-band connectors for the outlet. I have got a Datalogit now so think I am just going to go TD05-1G for street and Winton etc and 73HTA for Sandown, PI and giggles on E85
Yeh, I suspect that none of the turbos I am trying out will be the perfect all rounder. Will see. But since I am getting them all tuned I am just going to save the tunes and use Datalogit to throw the tune in for the setup I have bolted on. Changing turbo is quicker then a brake pad and bleed
Please select a turbo to suit your application haha. Kinda cool.
When are you going to get the tests done ?
Did you have a thought about trying out some other ecus while you are at it ?
Like vipec/link/haltech ? Maybe grab one from somebody to test out ?
You got all the great equipment, why not go further and push to the max.
E85, 4 turbos, best engine management. Who knows what would you be able to push out of the little RB20.
Edited by robots
When the Cosworth gets registered and I get the Skyline back from the work it is having done in Sydney. Probably start in the next two or so weeks. Firstly need to get all the turbos lined up and make sure I have all the fittings etc before I start.
So took some pics of the biggest TD06 exhaust wheel alongside the much loved L2 wheel.
Greddy TD06H-25G
25G Compressor
TD06-73HTA
L2 Turbine
73HTA Billet Compressor by Forced Performance
Side by Side
And this is what happens when you try to run an SH housing on an L2 turbine
I am holding off on going back to the std inlet as the new turbos may benefit from the extra flow up high in the revs at higher boost....the place where the Plazmaman is clearly better then std. If all the fuss over billet wheels hold true then I may get back to what I used to have through the mid range with the std inlet.
And yes, I have looked at the EFR turbos. But frankly until they are readily available and stop failing I am going to keep my money in my pocket. Plus, half the fun is playing with these things and seeing if they work or not. I trust that there are going to be dozens of results with the more expensive EFR turbos so will understand the merits of them.
Once I am through this round of testing if none set my heart racing I think I have found another setup to trial which should be good for a punchier 280rwkws. Thats the whole point of this testing...how to make the punchiest 280rwks possible
More than the turbo tinkering. keen to get my car back and further play with the suspension in it. Should be a little nicer with some recent changes, nothing huge but will allow me to move on knowing that suspension is as good as its going to get for a street car...with some little trick bits that nobody else has ;)
Loving this huge thread and Roy I Love my rb20 but I must say dam u love your car man ( in a good way ) rolleyes.gif ...
Anyway I've read this and that posts on here but I have a question before I buy on Sunday and I thought I'd ask someone who actually knows what the fek they are talking about..really.I have a brand new genuine trust td06 sl2 20g 8cm housing & 3inch intake available to me for 1k or a 3071r or td05-20g 8cm 2nd hand but still in good condition..i have used the td05-20g on my old sr20 and that was good from 4k til redline and made 800nm and 220 rwkw at 20.5 psi..I currently have a 33 turbo on my rb20 with everything supporting mod wise to make a big power hike xcept a turbo and that's where this comes in...I dont want the fastest car out there but want good power and hard when it comes on,would like 350rwhp and full boost by atleast 4.5k . I am leaning to the trust td06 but what would be better suited to the RB and would the td05 still be to small and not worth the work when the td06 could go in etc etc and is the wheel in the td05 the same as the td06?.. Also turbo will be going as a external setup with stock mani modified for a 38ml gate.
SORRY NOT HYJAKING YOUR THREAD BUT JUST WANTED A RELIABLE ANSWER thumbsup.gif
Cheers
Edited by Co-stan-za
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
