Anyone have any idea on what the GTR is doing?
There is a few symptoms:
- exhaust temperature light is on(when it comes on it does the stuff below)
- on idle it struggles to stay at a stable rev and conks out
- when driving it feels like engine drops power for a split second (driving along it feels like tugging on the handbrake quickly) numerous time while the exhaust temperature light is on
Faulty sensor? But I didnt think the sensor does anything besides lighting up the dash light when the exhaust temp is too hot...
If I cant diagnose it I guess I'll have to leave it to the tuners to figure it out since I'm booked it for a dyno run touch tune etc anyways....
https://www.sau.com.au/forums/topic/331137-what-is-my-r32-gtr-doing/
Its got a de-cat pipe in there though... it even did it with the standard cat which I had on for Vehicle Inspections for awhile - didnt drive it around too much when I had that on.
It only did it a few times ever before I put the standard exhaust/cat back on for vehicle inspection(roadworthy) and then it seems to be more frequent ever since, even after I put the aftermarket more high flowing exhaust on with the de-cat pipe.
coilpacks and spark plug has been changed, injectors no...
Why would it only happen here and there and only briefly though when the exhaust temperature light is on?
Seems to be more worst today as I took it for a drive, come home park it up, went elsewhere in another car for about half hour come back turn it on and it started doing it nearly straight away and conked out, drove it down to the car wash and it conked out as I left it to idle and hose the car down, turn it on drove it home(its only a 1 minute drive per way), went into my driveway and turn it off as the engine was struggling to have a stable idle - then needed to move the car about 15 minutes late so turned it on and it was still doing it doesnt stay stable and wants to conk out unless I keep my foot down on the accelerator so the rev doesnt drop down enough to conk out.
check which light you are seeing and check what it means in the service manual before guessing the cause
there are two lights that come to mind
one is the ENGINE CHECK LIGHT or orange ENGINE logo
the other is the EXHAUST OVER TEMP or RED CAT LIGHT
which one are you getting and check what it says in the service manual
ie no point guessing AFM's coilpacks etc if it's the RED CAT LIGHT as that's the CAT TEMP sensor warning
given you have a powerfc when the light comes on, use the hand controller and read what it is telling you
for an online demo and what you should be looking for check out
http://www.paulr33.com/powerfc-emulator/menu.html
you want to goto ETC, SENSOR SW CHECK
and then with the online emulator, learn how to work out what is wrong
Ah the PFC hand controller - I totally forgotten about that, took it off for vehicle inspection.
I just hooked it up, turned it on and left it to idle and after awhile it started doing it again so I quickly jumped back into the car and on the hand controller "AF-1" was highlighted and dropped down to 0.00v...
because the 32 gtr only has a cat temp light, not a cat temp and engine check light :D it is PFC showing you an error, looks like youv'e found it already.
if you can't easily get your hands on another afm to try, swap the 2 around and see if the error now apears as AF2
Hope its just a really dirty AFM, which it was - and I've cleaned it out with some contact cleaner earlier. See how it goes tomorrow when I take it out to the tuners for a dyno run check up and tune.
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
