  • Replies 174
I like those holden wallpaper esp the 1st one you made.. One of the shots could be straightned up more and perhaps added more light?? What do you think?
Can you make me on of my car :( pretty please!! heheh
Basti - i like the moody feel of the shot, but would have liked to see more of the background for this style of pp. Havnt seen you post pictures in ages.. where you been hiding?
my first shot with my only umbrella setup... i've got 3 cactus receivers but only one flash :(
Dont worry sometimes all you need is just one light source!! Keep at it.
Would like to see the colour version of this. I reckon with the flash you could make that green grass vibrant.
hmm well thats a slight crop. i'll see if i can get up the original when i get home but i think i saved over it. i've just been lazy and busy with other things recently. and i cant find my nifty50 :(
Matt - Difference between a shoot-thru and a softbox is that the softbox is more directional and a larger light source therefore spreading more light and less light fall off.
The brolly would be the same as a softbox effectively at a further distance but using more power in your strobe/flash. The softbox is a lot softer as well depending on whether you use the inner diffuser as well as the outer and/or a grid too.
The light also isn't as harsh out of a softbox.
We can make a wallpaper one time soon sidd. no problems! I have a backup receiver for the flashes now so the lighting problem i had shoudln't be to much of an issue in the future i hope.
thanks for the explaination between boxes and brollies. i'm 100% new to lighting and haven't really had an opportunity to play with either enough to work out the properties of each. I'm thinking i might get a cheap brollie soon just so i can compare and learn whats good and bad about each.
Took this on the weekend, It's not a car, but i like the dark look about it.
No worries matt. It's pretty cheap to get a lightstand a brolly as well as a flash bracket from image melbourne. Pretty sure you can get kits as well now. Around $100 or cheaper.
Nice Barra! I'm guessing the flash was camera right as you can see how the light falls off. Good exposure too, maybe a touch brighter but great job!
Invest in a Dell IPS monitor and calibration software like Spyder 3 or Eye-One or Color Munki. All good devices and give you accurate colour day in day out.
I use a Dell IPS monitor as well as a second screen for browsing the web and spyder 3 software on both. Well worth it!
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
