depends. The bf's bro has a 34 series 2 sedan wth the stock lip, not wing. Looks good still.
I think 34GTR's need to have the wing otherwise it just hasn't got that presence that GTR's are associated with. stock look ftw. Other 34's I agree, depends how you do it and what sorta look you're trying to achieve overall.
  • Replies 45
Posted Images
de-winged 34s FTW...
unless you have boot holes, that shit isnt cool lol :D
drift lip on the way!
It depends how u do up your r34/skyline.
But mine looks good with it on.
LOL - I'd say the opposite... R34s with no wings should be illegal :blink:
x2
r34 sedan with spoiler is illegal lol
Eh, I personally think R34 sedan's without spoilers look dumb. I upgraded mine from the standard sedan to the coupe spoiler because I felt it suited the lines of the car far better - gave it more 'balance'. Here's a pic of the result:
... eh, maybe you guys don't agree - but I prefer it.
>>> FTW .
how do i upload pics like that??
needs moar low asap
the autostyle 34 gtr pulls it off without a wing
depending on the cars stance, kit and wheels will determine wether wingless will suit or not IMO
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
