We are basically familiar with the footage of the Mines R34 Step 2 lapping the Ebisu cricuit. As best i can tell, the specs on this car are as follows:
- Std bore x stroke, cranks/rods/pistons
- Mines exhaust manifolds & dumps
- HKS 2530 x 2 turbos
- Mines 260 intake & 252 exhaust cams
- Mines ECU
- 600cc injectors and 270 L/h pump
- Titanium exhaust and carbon fibre bits and pieces
Now as best i know, the Step 2 car seen in the BMI footage is NOT the same spec car as recorded the 57.74 second lap at Tsukuba. The 57.74 car is the Step 3 which has additional mods
So watching an old tape the other night i found it interesting to see HKS's own R33 GTR car using the 2530s. Known as the T-002, the specs are as follows.
- 87 x 73.7 , by way of HKS pistons and rods - 2627cc
- HKS exhaust manifolds & dumps
- HKS2530 x 2 turbos
- HKS 272 inlet & 272 exhaust cams (+ Step 2 valvegear)
- HKS GT intercooler
- HKS injectors & fuel pump
- HKS F-Con ECU
- HKS 6 spd with Tilton twin plate clutch
- Power claims 720ps
The car appears to have std panels, with only some trim and seats removed for weight reduction. Now the footage of this car is impressive, but accelration is nowhere near as violent as the Mines Step 2 car which is still using the std R34 6-spd vs the close ratio HKS 6spd box
The HKS T-002 car lapped Tsukuba in 58.71, which is about a second slower then the Mines Step 3 car.
So got me thinking about the BMI R34 Mines Step 2 footage. No doubt the weight reduction seems to play a huge part in the performance/acceleration of the car, but...
... what are the chances that Mines have dialled in massive boost, fuels and a built bottom end to get the performance they did, then only to claim a lower state fo tune?
https://www.sau.com.au/forums/topic/33247-mines-r34-v-hks-r33/
  • Replies 74
Firstly after reading the magazine article..
http://www.skylinesaustralia.com/fo...ead.php?t=28936
got me keen in following mine's spec with my 34 when it arrives late this year.
I started a thread some weeks ago..
http://www.skylinesaustralia.com/forums/sh...ead.php?t=31827
& got a little help but not much.
Some things I found out were,
Engine: is not stock, all the internals are lightened & strengthened, bore is the same.
Boost: 1.4kg/cm2 "I think this is around 30pound" but temember reading they used 34pound"
Some things you missed:
Carbon fibre proppellor shaft
Total weight has been reduced to 1300 kg :wow:
Overall they claim around 630~hp. I've think that the mines car is "claimed to be the most standard" & other brand name cars are unrealistic for day to day driving. In the latest HPI mag they have an article about brand names fighting for time trial "nighthoods", best times = sales $$.
Anyhow here's the link to the mines N1 gtr:
http://babelfish.altavista.com/babe...tr%2Findex.html
See below a quote from Rezz, when I asked whether the reduction in weight could really reduce the mines gtr, by 250kg...
Yes!!... I think you'd come to the same conclusion after seeing the HKS Full Carbon bodied Evo VII. The Japanese have really concentrated on weight reduction in the last few years, just look at the C-West S200, the HKS Evo VII, Mines cars, the Cyber Evo Evo VII... seeing all those cars in action, they are bloody fast for what they are, eg: buyable road cars. My point is, the Mines R34 GT-R is but one of the super fast track cars in Japan, so at least to me it doesn't seem so unbelieveable that it can be as fast as what it is.
Here are the spec of the mine's car...
The highest output 600ps/7400rpm
Largest torque 60kgm/5400rpm
Boost 1.4kg/cm2 = "i think this equals around 30psi"
ENGINE: Stage 2 "Basically strenthed items & lightened pistons"
CAMS: IN 252°/lift 9.1mm
IN 260°/lift 10.2mm
EX 252°/lift 9.1mm
EX 252°/lift 9.5mm
CAM GEARS: Mine Adjustables
HEAD GASKET: Metal
INJECTORS: 600cc
ECU: Mines
AFM: Doesn't say "but does mentioned capable of 600ps"
TURBINE: HKS GT2530
PROPELLOR SHAFT: Carbon "what this?"
FUEL PUMP: 270L/h
EXHAUST:
Muffler silence VX PRO TITAN (90-115 Φ
Front Pipe Mine's front pipe PRO TITAN (70x2-100-90 Φ
Outlet Mine's super outlet PRO (70-70 Φ
Air Filter Mine's VX air filter
AERO PARTS:
Diffuser Few sir Mine's carbon front D
Main Wing Mine's carbon main wing
Rear Wing Stay Mine's carbon rear wing stay
Rear Wing Mine's carbon rear wing
Trunk Mine's carbon trunk
Trunk Spoiler Mine's carbon trunk spoiler
Air Duct Mine's air duct
Mirror Mine's carbon aero mirror
Radiator Shroud Mine's carbon radiator shroud
マインズオリジナル = Mines - Thanks to the Merl'star
Firstly, for those who can't read katakana, "マインズオリジナル" means: Mines Original.
Nothing exciting, but helps to know I guess...
Also, although not listed on the above spec sheet, watching the video of the Mines R34 lapping Tsukuba, it's obvious that the car is lower than standard, which suggests an inordinate amount of suspension changes on the car... The Japs don't muck around when setting up their track demo cars.
Secondly, the smaller camshafts on the Mines R34 would help in the faster revving of the engine from 4-5000rpm as seen on the video as compared to the larger 272/272 cams in the HKS R33...
As discussed in the lightened pulley thread, any weight reduction in the drivetrain rotating mass will result in a very noticable response increase, and the carbon prop shaft would contribute a lot to this...
I haven't seen the video of the HKS R33 lapping, can someone please host it for us?
meshmesh, the list of engine parts doesnt list pistons for the Step 2 Engine... are you sure it has forged pistons. (but appears to have std rods and crank)
Either way both cars are impressive, perhaps dropping weight and as Merli said modifying suspension (all that carbon droping the centre of gravity) contributes to the cars stunning performance.
nothing is ever what it seems.. and in motorsport, as most people would know, its no different. Games, games, and more games, thats all it is. To claim any of these cars are "stock" or sticking to some formula is no more believeable than any "standard" F1 car exploit.
Thats what im trying to get to the bottom of, imagine someone forking out the 15k for 2530s, manifolds, cams, ECU and injectors, only to end up with an additional 50-70rwkws (say about 280-300rwkws), when they thought they would be getting a MINESeque performance...
That said there is no doubting with those 15ks worth of mods any normal person would still be giggling like a lunatic... :D
...oh and what may help you guys identify the car is that the T-002 was also used as the HKS 0-300km/h car, firstly with GT2540Rs which equated to a time of about 23.## seconds from memory, then later with GT3037S which saw it bag a time of 17.84seconds.
I think the mines car also has massive 6 piston brakes and incredable sus setup. I think this is were a lot of its speed comes from. In one of the BM VCDs there is a R34 GTR battle. Most around 600HP and one with 700+HP and yet the mines is quicker than all of them by at least 1 second a lap. It seems to have a great setup as it looks a lot more stable and allows better power delivery to the ground. Its pretty much the only one not lighting up all fours on the exits of corners.
Cheers
Brakes are AP 6 piston.
Suspension is Ohlins.
That GT-R BM 6 car battle is available for download off various sources.
T.
Is lighting up all four tyres really a sign of great susp setup? But i think i know what you are getting at... I have the R33 battle, but not the R34, can someone post a link?
Nismo32 said that the Mines R34 GTR was the only one NOT lighting up all four on corner exits :D
I think the guys at prospec have said that the thing they did to their cars that made the biggest response difference was the addition of a carbon fibre prop shaft. So much focus goes towards the engine but this could be an important key to supreme performance.
Hi guys, things I noticed;
^ Mines are very experienced circuit racers
^ Do they even have a factory drag car?
^ They concentrate their efforts on response from the engine, not outright power
^ The fast circuit race GTR's on "R" type tyres don't have more than 650 bhp (in general)
^ Even the Gibson R32's had around 640 bhp and they ran on slicks
^ They run high compression ratios, over 9 to 1 is common
^ The Gibson R32's were 9.5 to 1
^ They use turbos that are at their most efficient at that power level, they don't use a bigger turbo/turbo's and run them inefficiently
^ This seems to indicate that they won't sacrifice response for outright power, 10% better response must be better than 20% more power
^ They don't use big cams, this keeps the power band wide so it never drops off in corners
^ Before it can accelerate the car, the engine has to accelerate itself, so they use lightweight components like crank, rods, pistons, valves, retainers, buckets etc
^ Then it has to accelerate the other rotating bits, stuff like pulleys, flywheel. clutch, gearbox tailshaft, diff, drive shafts, brake rotors, hubs and wheels (you can bet they don't use heavy chrome wheels) etc
^ The car itself has to be as light as possible, this means less weight to accelerate, less weight to stop, less weight pushing out in the corners etc
^ a 20% weight reduction is thus better (faster) than a 20% power increase
^ They use Ohlin's double adjustable dampers, arguably the duck’s guts at the moment
Last, but by no means least, I can’t afford Mines prices, they make my nose bleed, they are so high
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
