  • Replies 48
all this reading on 2 way diffs has got me interested.  so how noisy are these things compared to stock??  like would i be able to hear it in the cabin over an exhaust or outside if i stand on the streets??
They are only noisey when taking slow corners.
So taking off from the lights and doing a 90 degree left turn you'll be able to hear it. And so will the people standing close to the car. But if you go around the corner with netrual throttle (not accelerating and no deccelerating) there's no noise as the diff only locks up when accelerating or deccelrating.
Reverse parking can be a little noisey too, backing out of drive ways etc..
I also find that when the oil in the diff is cold (first thing in the morning) it's like a stock LSD. But once the oil is warm/hot it does it's thing :P
J
https://www.sau.com.au/forums/topic/33288-lsds/page/2/#findComment-672188
Late 60's F1 cars were set up with differing ramp angles on accelerate and trail for exactly that kind of handling.
And I think this is the difference between a 2 way and a 1.5 way. Eg. 1.5 way locks up faster in acceleration, and locks up slower in deacceleration. While a 2 way locks up the same either way.
Or should I say - the difference between the 2 and 1.5 ways is that the 1.5 ways don't lock up as fast in deaccelerating....
Anyone know for sure??
J
https://www.sau.com.au/forums/topic/33288-lsds/page/2/#findComment-672543
thanks Jay95r33.....im sure i can live with that if it does its job in the end:D might have to find someone with one and go for a ride.
how much do these normally fetch for?? and is there any particular brand that stands out from others?? the hicas is totally eliminated too rite?? so i can scrap gettin the hicas removal bar and put that money into a 2 way diff rite??
https://www.sau.com.au/forums/topic/33288-lsds/page/2/#findComment-672615
That's cool,
By the looks of it, secondhand ones go for around $500. Not sure what the differeces are between brands, but maybe stick with a big brand (Cusco, Nismo, ATS etc..) if your unsure.
Another thing is that your rear tyres will wear a little quicker than normal. This is due to the skipping, plus the fact that they are so fun to drift with :worship:
The HICAS is totally seperate to the diff, so you will still need the HICAS lock bar if you want to disable it.
J
https://www.sau.com.au/forums/topic/33288-lsds/page/2/#findComment-672681
$500 is a very, very good price for a decent second hand 2 way diff.  Realistically expect to pay 800-1000 for a good one.
I have been looking for one for a while, cheapest (until now) I have seen is $850, dearest around 2K.
Did I mention I just picked up a 1 way for $350:D
hehe told you they want to get rid of them :worship:
1 way is just lock up under acceleration, no effect under braking.
I haven't tried a 1.5 or 2 way to compare, but the traction and predictability out of turns with the 1 way is *amazing*
https://www.sau.com.au/forums/topic/33288-lsds/page/2/#findComment-672854
Jay, yep basically. If you could imagine the 'ways' referr to the locking characteristics of the diff, 1 locks one way, ie accelleration, 1.5 locks on accel, half locks on decel, 2 ways locks two ways accel and decel.
skids, really, 1 way is fine, very predictable when accelerating, but wont lock when you brake, so if for some reason you need to brake into a corner, less likely to kick the back out.
https://www.sau.com.au/forums/topic/33288-lsds/page/2/#findComment-673463
Just a note on the HICAS lock bar. I'm building one now and the threads are a 16mm x 1.0 thread pitch. Entirely uncommon in Oz but you can get a bottoming tap for a bargain $65......ouch. Oh well it is cheaper than the off the shelf items.
https://www.sau.com.au/forums/topic/33288-lsds/page/2/#findComment-673502
i would recomend a 2way for the street, depending on how you drive.
I have a 2way, and the thing i love most is that when the tail is out, and i get nervous and back off too suddenly or early, the back end sits firmly planted, with no snapping back, spinning round, or fishtailing. Its saved my arse a few times.
id only see a one way good for launches and power oversteer for the experienced.
https://www.sau.com.au/forums/topic/33288-lsds/page/2/#findComment-674226
Update, diff arrived, and surprise surprise its a 2 way nismo:D:D:D so I reckon I got close to the bargian of the century - absolutely stoked.
I didnt realise quite how bad the stock diff is until I fitted this thing. especially noticeable when coming onto boost and taking off at the lights where I used to get the rears (or one rear) chirping all the time. Now I can just feed on the throttle as I move off and she just launches - heaps better, feels alot quicker.
The transition to oversteer is so much better too, no longer just snaps sideways, just gradually moves out and then comes back nicely (unless you just go nuts with the loud pedal).
If I knew how bad the stock diff really was, I would have upgraded along time ago.
https://www.sau.com.au/forums/topic/33288-lsds/page/2/#findComment-687883
    • Hey crew, Failed my WOF cause of a lower control arm, and I've decided to hit both arms, and also the compression rods at the same time(seems they're gonna be the most likely upcoming failure points from some discussions with the lads over on the G35 reddit). I've looking at these form Z1:  https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-compression-rod-p-40716.html https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-lower-control-arm-p-40674.html I asked Z1 if they'd work as it's the same platform, just RHD vs LHD. I basically got told "Lol dunno". Specifically they aren't aware of any difference but can't guarantee fitment as they haven't done it on a 350GT. So guess I'm asking is if there is any issues with using 2005 G35 coupe suspension parts on a 2005 350GT coupe? Orginally I thought it could be something in the way of the arms that each control arm is designed to be positioned around, but that'd be an engineering nightmare for Nissan needing two different shaped control arms 😅
    • ^ This. The mode door actuator is a common failure, as is the actuator and/or the actual valve for the coolant flow control valve. I also don't know how available the mode door actuator is these days. I've been meaning to look into it and get one from wherever is possible, to keep in the shed for the rainy day when mine eventually fails. Anyway, the advice to you is to search the usual NOS part supply places, or even just go to Nissan and see what they list.
    • Have you got a pic of the actuator? My guess is that unit has failed internally and was flopping around, so the previous engineer who owned it forced it to be fully open to cold air (blocking the heater core path). As far as you can tell, is anything else wrong in the system? Likely you just need a new actuator (not sure how available they are) and then "installation is the reverse of disassembly"
    • I'm happy with the Lsailt unit that I put in, it puts full Android on the top screen so you can run whatever Nav and other Apps you want, while still existing inside the factory functionality like automatic reverse cams, audio input switching, retains factory bluetooth etc. Not cheap and the install was moderate (not simple, not hard) Yours is a V36 not V37 though right?
    • Yeap, all the NC's that I originally looked at that had a hard top were PRHT, which makes the roof line look horrible, hence why I said nope to them My only caveat for another MX5 was it needed to have a hard top, and initially I didn't think you could get a detachable hard top for the NC,  like my NB had Again, a big thanks to Matty for helping me source the detachable hard top for my little girl, they are as rare as hens teeth in Australia, and the few people who have them, keep them Also to Greg, for initially pointing me in the NC direction NC PRHT 🤢🤮 Not mine (I really should take more photos of my car), but a NC with the detachable hard top 😁 To me, the difference in how the detachable hard top roof line looks, and how it actually follows the bodies lines, like they do on NA's and NB's, is chalk and cheese compared to the bulbous looking PRHT
