you could temp we with that offer Brett
especially if we goi to 4 on 6 off
Ken i said pimp to get in before joe said it hehe
and Jay is my bitch, Kyles is all mine i pimp out guys u see PVA is another of my bitches he gets lots of customers.
S13_Angel Kyles might be interested info about your work. Shes doing a teachers aid course next year at uni. atm shes full time child care worker.
  • Replies 86
Extra work is always welcome Brett but I already work every week night, and I am seriously looking at going back to uni next year so I'd have to cut back on hours anyway.
Day time work is another issue, get me in the door at DOLA mate, I've had to stuff around with IDRISI before :)
Who doesn't work in Oil and Cas Industry?
Because I do too.
I subcontract myself out to Oil and Gas companies as a Instrument/Electrical Designer.
Currently working on Trains 4 & 5 of the LNG plant in Karratha
Cheers
quote:
Originally posted by puckish
Dildo Model...
Originally posted by skyzerr33
they wont be very big
Umm yeah I take it you purchased some
:uh-huh:
    • Hi guys my TPS voltage is reading over 2v at idle.  My Haltech ECU is reading around 40% throttle position at idle also which is really strange. Note the actual throttle position sensor is brand new…    anyone have any experience with this or know how to calibrate it on Haltech ?
    • The OEM disk will not work on any AEM ECU, you need to use the one they made. You shouldn't have to flip the CAS or whatever you were describing, if you set the ignition sync offset correctly it can't backfire. Make sure you're using a spark plug lead on coil 1 instead of the timing loop to avoid weird issues with the timing light. Double check that your timing settings are actually correct, like is the 24 tooth configured correct or should it actually be 12 teeth for 1 crank revolution? I also found this: 305817248-AEM-Undocumented-Settings-v1-2.pdf
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
