I'm going to relocate the battery to the boot and I'm wondering if anyone has used kits for this type of thing or do you all just go your own route and source parts you need.
I'm not auto electrician so I'm not fully versed on what parts are required.
As I see it, some heavy gauge cable to connect the battery to the engine bay terminals, I'd imagine some sort of heavy duty fuse for safety and I'd like to put an isolation switch in to stop the battery being slowly drained while the car sits as it's not driven regularly.
What's going to be the best way to go about this. I'm all for DIY just not sure what's required.
https://www.sau.com.au/forums/topic/334147-battery-relocation-components/
  • Replies 63
We are looking at doing this in our R32 with the cable etc from a R33. This can be easily obtained from a R33 wreck and it comes with all of the protective covering from the R33.
I've just finished doing this. Sprint Auto have metal battery trays that you put in the bottom of the battery box for $15.00.
The cable is only $7.50 / Metre.
I used spiral wrap around the cable to just it extra protection.
I did this on my S15 and in the process of doing the same on my s14 now.
Try to use a dry cell if you are mounting in the boot or inside the cabin.
If you want to do it yourself just measure up the length of cable required by running a piece of string or rope along the required path and cut it/mark it at the required length.
Go to an auto electrician or a welding shop to buy the cable depending on what gauge you need for your application.
Use a fuse as close to the battery as possible.
Run the same size earth from the battery to the body as the power cable and make sure you get a good contact.
A battery isolator switch is a good idea if you are not going to be driving the car regularly and I also got myself a battery charger that I can just leave on when I'm not driving the car.
This time I purchased a kit as I want everything to look a bit neater this time but it wasn't cheap.
Cheers
Jamie
Yeah, the conduit does make it look a lot neater. And if you get carried away and want to wrap it in black elec tape it almost looks factory.
Not sure about the boxes - I am looking at these fused +ve terminals http://www.projecta.com.au/catalogue/cid/35/asset_id/84, then a key type kill switch for the cabin, and I need to run an external pull near the windscreen as well. Going to run an earth in the boot and one to the bay - that should have me covered.
So the general consensus is:
- 250A fuse on the +ve off the battery
- 00AWG (2/0) guage for +ve to the bay
- 4AWG earth in the boot and to the bay
Can any autoleccy's confirm this sounds right?
An auto sparky told me to run the earth lead from the battery to the front firewall, then from the front firewall to the engine block. This is if you have an alloy radiator, otherwise your cooling system can have some residual current flowing through it, causing electrolysis of the alloy rad.
Also if you have a normal wet battery in the boot, you either have to have it in a sealed, vented box (not a marine type battery box) or you need to have a liquid proof firewall between the boot and cabin (CAMS and DOT regulation). If you mount a wet cell battery in the cabin, then it must be in a proper sealed, plumbed battery box.
  • 2 months later...
I've got all my gear together now and am embarking on the job but I was wondering, do I need a blue trianlge sticker on the car now? It's only club level and still street reg'd.
I grabbed an isolator that will allow remote pull to swich off but won't be connecting the remote feature straight away. Will just leave the key in the isolator.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
