Hi guys,
Looking at getting a car cover because I'll be moving eventually and leaving the car at home. No room for it in the city. Anyone have any suggestions? It'll be removed every now and then when I come home, and for track events, but other than that, I guess something that's got a fairly solid "skin", to stop water getting through when it rains?
Just 2 seconds on google, are Kenco any good? Saw one on the Supercrap website, $129.
http://www.supercheapauto.com.au/online-st...id=4258#details
Any other recommendations?
(thought of this after seeing Chubbs lol it up in a SAUVIC thread)
https://www.sau.com.au/forums/topic/334515-car-covers/
i use to work at supershitauto, years back, all i remember get one with a good inside, and make sure your car is clean, if you got a dirty car with anything over it in the wind and that shit will rub and scratch. cant really remember which was the best... but i do remember you get what you pay for
https://www.sau.com.au/forums/topic/334515-car-covers/#findComment-5419588
I had a autotechnica brand one for a few years. It was silver in colour was soft inside and had padding on top to protect it from falling sticks and hail. got it from Autobarn, its nice and thick and lasts for years. I tried another cover that was quite thin and it only lasted a month before i took it back for a refund, so i recomend getting something on the thick side.
https://www.sau.com.au/forums/topic/334515-car-covers/#findComment-5419663
Two seconds on Google, Owen:
CarCareProducts.com.au
and
CoverCraft.
(CoverCraft are pretty much 2mins from my house, so if you find something and order it, I can pick it up for you and save you the cost of shipping.)
https://www.sau.com.au/forums/topic/334515-car-covers/#findComment-5419952
and
CoverCraft.
I hit Google up and had heaps of sites; just figured some people here might have used some of them before and swore by them :(
Looks good man... If I end up getting one there, I'll let you know.
https://www.sau.com.au/forums/topic/334515-car-covers/#findComment-5419967
One thing to keep in mind. Try and find one without any stitched seems running through the middle or anywhere but around the edges. Basically look for a one piece otherwise any seems will scratch the crap out of the paint any time it moves.
https://www.sau.com.au/forums/topic/334515-car-covers/#findComment-5439619
and just to be on a safer side... get an old blanket or quilt and put that on the car.. then wrap the cover around it... for teh extra sofffffffnessss and make sure it's tied properly... like ... really tight.. that is all.
https://www.sau.com.au/forums/topic/334515-car-covers/#findComment-5440173
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
