Hel Stainless Steel Braided Clutch Line Group Buy
  • Replies 187
After one to suit R32 GTST with R33 slave
The Hel R32/R33 GTST clutch line is identical so therefore it shouldn't matter. Does that sound correct to you? What is on there at the moment?
LIST UPDATE
1. PMR33 - R33 GTST
2. 89CAL - R33 GTST
3. 33DRIVER - R33 GTST
4. MATTIS96 - R33 GTST
5. GIMPS-R34 - R34 GTT
6. DYSONEST - S13
7. JPCR33 - R33 GTST
8. GTR32R - R32 GTR
9. NA BEAST - R33 GTST
10. ADRIAN P - R33 GTST
11. MARK660 - R33 GTST
12. GOTHIK33 - R33 GTST
13. MR SCARY - R32 GTST
14. TYPEVU - R32 GTR
15. BLAGS - R33 GTST
16. SKINS - R33 GTST
17. HIBINO - R32 GTST
Edited by PM-R33
just running RB20 box and slave atm. Putting 33 box and slave in when it arrives. I assume they're the same as people just swap the slaves over. So yeah, R32 GTST one should be right.
So that's nearly 20 people, might aswell see if it gets to 30 again and I'll end it at that.
Edited by PM-R33
so ive just found this from a guy who just did a manual conversion on his stagea: "Clutch line - 650mm Long with banjo bolt on one end and jam nut on other."
he used an R34 slave and master, rs4s runs an R34/GTR pull clutch so im going to have a stab at an R34.
EDIT: i am retarded, my housemate has an R34 GTT and it only just occurred to me that i should compare them. same same.
R34 GTT please.
D.
Hahaha too easy man, cheers.
LIST UPDATE
1. PMR33 - R33 GTST
2. 89CAL - R33 GTST
6. DYSONEST - S13
8. GTR32R - R32 GTR
18. J RED33 - R33 GTST
19. OJR32 - R32 GTR
20. PINTALINE - R34 GTT
Edited by PM-R33
I wonder if nissan fast could helP with part numbers if anyone else has stagea etc problems. Couldncompare stagea lines/parts with skyline models or something? Unless the previous post has cleared that up lol
Any more takers?
If some of you guys that allready have my bank details want to start sending through the money that's cool. I'll leave the group buy still open till the end of next week like I said but i'll start PMing every one to make payments so we can get this puppy on the road.
Edited by PM-R33
Compared all 4 parts of clutch line for WC34, all parts match R34 GTT (RB25DET MT5) See attached doc for all 4 parts of hard lines for WC34 Stagea
clutch.doc
Hope this solves.
Edited by Adrian P
sweet, Nissan Fast saves the day again lol
Ill send money your way on Wednesday when I get payed Phil... Im just back from holidays so the bank account is a bit low lol
Hey Phil,
Chuck me down for an s1 r33 gts-t please mate, as per our PM convoy.
I'm skint until next Friday. Ok to pay then?
Cheers,
Aaron
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
