Hel Stainless Steel Braided Clutch Line Group Buy
I have no idea man. You got a link? I could never find whether it was a replacement of the whole line or just the rubber line. In theory though there is no need to replace the hard lines since they can't expand.
  • Replies 187
Too easy Ben, glad to see the QLD guys are getting them today.
Yeah I wasn't really sure on what the GTR line replaced since it was a different length than the GTST one. But I figured you GTR boys have some weird funky setup due to the AWD hence it being different :P
I think the GTST one replaces the block, but I shall soon see.
Well, I got one for my GTS-t, not the GTR..... Box is marked "suit 32 GTS-t" but I've been looking this morning and I'm mildly confused. lol
Let me know what you guys find?
Oh yeah that's right, you had a GTST kit, my bad :P
My mate has his engine out at the moment so i'll quickly dummy fit the clutch line from the master cylinder and see how it all fits.
Edited by PM-R33
So here is the clutch install on my mates GTST.
As you can see it replaces the entire factory setup :D
Here is the massive factory line removed.
For those kids keeping track of their cars diet here are the results:
Factory setup - 828g
New clutch line - 97g
Weight saving of 731g
Not bad ay :)
It's finished man, hence the pictures above of them fitted.
If I do one again i'll let you know.
Edited by PM-R33
Groovy!
My engine and box is out at the moment so I couldn't get a picture of it in my mind. That's a great weight saving! I'd spend an entire day trying to save that weight elsewhere :D
Yeah it's pretty decent. And in reality it would probably be closer to 800-900g because there would be less fluid used in the new clutch line compared to the amount that runs in the factory line :thumbsup:
Edited by PM-R33
Mine landed yesterday, with the brake line.
Cheers Phil, muchos gracias!
That looks awesome getting rid of all that factory crap lol will be much neater. Will have to put mine in on the weekend. Pics help alot
Thanks again Phil :)
Thanks guys.
I'm going to look into whether HEL would do some custom made braided lines to replace the four brake lines on the firewall (for ABS models) or two brake lines on the firewall (non ABS models) that go from the master cylinder.
No real "performance" benefit but I figured for the good prices we are getting these at it would be a nice looking mod in the engine bay :) I've seen a few pictures of guys that have done it and it looks quite good.
I'll let you guys know if some of you would be interested; I know one of my mates is very keen.
Edited by PM-R33
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
