Hi there,
I have an r33 4 door that i got about 2 months ago off a friend of mine, I have been having an ongoing issue with bad boost creeping and spiking. I have a standard turbo running front mount and split dump pipe ( apparently bought off a guy on this sight that makes them), and a pod. now as soon as i go full throttle, the boost just keeps going past the actuator setting anywhere from 10 to 14. I am not running a boost controller. I have put a piece on the hot pipe to run line to actuator, and also replaced actuator aswell. Nothing changed. still over boosting. I detached the actuator arm today and wired the flap open as far as it could go and went for a test drive. Still the car boosted up by about 3000 - 3500 and kept rising to about 9 psi, maybe even 10.
With it open, shouldnt i only get maybe a couple psi by redline, not 9 or 10. I am thinking the split dump has something to do with this, I have checked for boost leaks everywhere i can, and replaced some hoses. I am leaning towards going back to bellmouth dump, i have been told they a a lot more stable on boost and keep the split for when or if i decide to do ecu and tune.
Anyone that has been through this, knows anything about this sort of thing, please shed some light and let me know if i am maybe on the right track.
Thanks to everyone for there help.
Josh
https://www.sau.com.au/forums/topic/335014-wastegate-flapper-issues-maybe/
Hi there,
Josh
I have the same issue with my turbo, the internal flapper hole is to small.
I opened it up by a few mm but the problem is still there,
I'll be fitting a external gate.
Nigel
I had no problem with my off the shelf split dump but if yours is catching the wastegate surely a few minutes work with an angle grinder should "adjust" it to fit rather than buying a whole new front pipe.
had same problem with a split dump, put back the origional, had same problem, put on a aftermarket bellmounth, same same, opened up the hole big as possible, fixed, blew it up a day later :)
Thanks for the replies so far, seems people have mixed views on this subject. I have also been told that split dumps flow so much freely and that can cause wastegate creep also, something to do with pressure. Not sure myself. Any ideas if I will lose much power by going back to a bellmouth.
i dont know if this could cause it, but jjr split dump pipes are pretty poor quality (if its a jjr one, but this being said, maybe a lot of them are like this), im not saying this because i hate jjr or anything but from hands on experience, when i bought one before my bellmouth, i inspected it and noticed that the hole for the wastegate pipe that joins to the main pipe is poorly cut, and in actual fact is only about 50%-75% size of the actual wastegate pipe, so say that the wastegate pipe part of the split dump pipe is the site of a 50c coin, the opening on the main pipe is only the size of a 10c coin... i fixed this by spending about an hour filing away at the hole, but all this being said i dont think i had any issues with boost creep that wasn't boost controller related, i used to get boost creep right up to 14psi (when the boost controller was set to 12psi) i fixed this by getting a evc, but a turbotech boost controller is just as good.
hope some of the this info sheds some light
split dump for sure if your problem. put a bellmouth on.
why f**k around trying to get a split dump working (grinding bits and pieces) when the split dump gives you no performance advantage? 2 small pipes has much less surface area than a bellmouth that covers the whole turbo exhaust flange, and tapers down to 3" nicely. plus, with the dump you are using the full exhaust when you are off boost = better efficiency. with the split you are only using the main pipe.
put a bellmouth dump on. I've heard so many stories of JJR split dumps fouling the wastegate, boost creep etc. However their stainless bellmouth dump is actually quite nice quality. flanges are good, TIG welding is very neat and the finish on the pipe is fine. I was really pleasantly surprised when i received mine. there is no "maybe it will work maybe it won't" as with a split dump and whether the actuator fouls. then you get your split dump working, get a high flow they fit a bigger flapper on the gate and then it fouls again!!! screw that for a laugh.
Well I went with the choice of going back to a bellmouth. Not the best solution but for now it will do. If it solves my problem which I'm pretty confident it will. There is nothing else left for me to check, I will keep the split dump for when I change turbo's and do ecu upgrade.
You running a cat converter or got a decat pipe in there?
You can check to see if the gate is catching on the dump...unhook the actuator and check its range of motion...they will never open 90 degrees, if it opens to half of that its working fine and has sufficient clearance.
Edited by NSNPWR
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
