Got the M35 back from the radiator shop today for the custom top tank build, and when i picked it up they claimed when they unplugged the afm sensor (or map sensor whatever it is) with the ignition on and it made the engine light stay on, they checked everything (they claim) and they couldnt find anything wrong.
They claim they rang Nissan and Nissan wasn't sure but they then told me to unplug the battery for 30 Minutes at a later date which might reset the computer and the engine light staying on in the dash?
Anyone verify this ?
They also had to top up the transmission fluid which i mentioned had to be j-matic or matic-s. which they claimed they used and topped it up.
I took note of the kms before i dropped it off and they hadn't put any kms on it (unless they unplugged the dash fuses).
Slightly concerned now!
https://www.sau.com.au/forums/topic/335293-m35-engine-light-stuck-on/
unplugging the battery & pressing the brake/horn won't clear the engine light on an M35.
CLICK HERE for the procedure to clear any fault codes.
Alternatively, if there is nothing wrong, the light will turn itself off after a few hundred kms.
Edited by iamhe77
I was actually suprised they did Scott , as they mentioned it first and knew only matic -s was available (apparently a previous worker had an infiniti series).
So i was suprised as you ..because i was about go sick at them if they used dextron III.
ERASING:
•Ensure accelerator pedal is fully released.
•Ensure ignition switched OFF for at least 10 seconds.
•Switch ignition ON - DO NOT start engine.
•Wait 3 seconds.
•Within 5 seconds, repeat the following 5 times:
•> Fully depress accelerator pedal.
•> Fully release accelerator pedal.
•Wait 7 seconds.
•Fully depress accelerator pedal and hold.
•After approximately 10 seconds MIL will start flashing.
•Fully release accelerator pedal.
•Trouble codes are now displayed by MIL.
•Fully depress accelerator pedal for more than 10 seconds.
•Trouble code 0000 should be displayed.
where is the ecu that shows these codes ?
behind passenger kick panel?
ERASING:
•Wait 3 seconds.
•Wait 7 seconds.
It takes correct timing which is easy to stuff up lol
The codes will display by the engine check light flashing 1-10 times then a pause, then again 1-10 times, pause, flash again, pause, flash again.
Each time it flashes, write down how many times it flashed before the pause (if it flased 10 times, write down a zero).
This will give you your error/s in a four number sequence.
The Ecu is behind/above the glovebox but it is quite uneventful to look at.
Undo battery terminals
press horn/brake pedal to release leftover current
reset battery terminals
check light should be cleared
lol....really! :D
Edited by Jetwreck
lol....really! :P
Well, on my C34...
LMFAO..
damn you beat me to it Dale!!! lol
Sorry dude, I just couldn't resist! :)
*nice Cam says* Ooh, look at all the hoity-toity M35 drivers and their in-joke. Nice way to show your appreciation for another forum member trying to help out
*normal Cam says* Shut the f**k up Nice Cam, that is f**king hilarious :D
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
