hey guys,
i am putting together a rb25 just for street use.
At the moment my current setup on my current motor is
3071R
plasmaman
6 boost manifold
all supporting mods exhaust, fmic, injectors, pump, vipec. etc
I have got another Rb 25 that i am about looking at assembling,
its only done 70 thousand kms, i've pulled it apart and all bearings, rings, piston clearances are within factory tolerances.
i am looking at freshening it up with:
Genuine nissan headgasket
genuine nissan bearings, mains, thrust and big end bushes.
Cosworth Forged pistons (standard bore size)
re-using standard head bolts and rod bolts.
I'm going to upgrade my 3071R to a 3076R,
looking to push about 300 rwkw. and still maintain drivability and a reliable motor.
anything else that you guys recommend while i have got the engine apart?
i'm not sure what kind of psi is needed to get to 300rwkw, but i believe the standard headgasket and head bolts are up to the job.
Are forged pistons overkill for the job? i don't mind using standard pistons.
if there is anything else that would be a good idea to do while the engine is apart. ive searched through the forums already, maybe there is something i have missed
cheers
From the reading I have done from people and there results and how theve built it I would say the idea you got going at the moment is right for the 300kw mark and personally I would upgrade the pistons and the headbolts just for peice of mind.
To run 300 you would probably be running 19-20 psi with the 3076 so in regards to head gasket I would probably go for something aftermarket as most I have read are running about 18psi with standard one. I am no expert in the department as have not built my own motor but thats just what ive gathered in my research.
its probably a good preventative measure to replace them with arp head studs,
Standard head bolts look to be Sturdy and high quality tho.
Ive looked into an mls head gasket, i'm undecided as i don't really want to get the block decked just to put one on.
anyone else put a mls headgasket on without decking the block and giving a quick clean up with a wizzer and some flap wheels?
i just wasn;t to sure how tolerant they were compared to standard style headgaskets.
hey mate im building mine now slowly and aiming for simular figures. was only 85 for big end studs and head bolts 250 from memory. worth investing in anyway. wouldnt worry about stock headgasket unless stock boost. i went king bearings but nissan ones are good
as for the comment about getting block decked its not really that expensive unless you dont want to strip it right down. but if its out go 4 it. was quoted $260 for bore out 20 thou and hone. $82 to acid bath crank and polish. $82 to deck/mill block and acid bath. ended up getting that all for $250 mates rates but you never know if its been hot before and warped etc
machining is cheap, i thought i was having a good run on the stock head gasket atm seems to be good on my current standard motor @20+ psi
Do it once, do it right. Don't re-use the factory head bolts, rod bolts or the factory pistons.
I will prob go the rod bolts aswell as a the arp head bolts. Standard Rods look quite robust.
put a crank collar on,i wish i had now im taking the motor out again to do it.
With this crank collar. i take it the factory crank collar only goes iunto the pump drive 5 mm or so. aftermarket collars go into the oil pump 12mm(?). so less chance of slip or braking
do you have to rebalance the crank with this new crank collar? still fine to use the factory oil pump with the upgraded crank collar?
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
