  • Replies 210
ahhh clever lil man u are. Is that how all panel beaters do ti or is this your preferred method.
Lead loading is a thing of the past....not many people have the patience to do it these days ....although its the right thing to do in spots that get flexed such as door pillars ect....body filler is quite good these days but in these spots it may eventually crack or fall off......All panel shops are most likely to have a spot welder which welds on brass pins for pulling...i like the magna spot coz its a portable unit but it but low on grunt for the thicker gauge material but its great for door and 1/4 skins.My repair process takes a bit longer than shops method only due to extra care on feathering out and a few other bits and peices
but everyone does things diffrently i guess...there are a few cheats you can do to cut down time but good preparation = a good and long lasting paintjob so id rather take extra care now than pay later...after all..you dont want to do this to a car twice :D
But whether they choose to use it or not....had a bump not long after getting my first r33 in 98 and the panelshop wanted me to pay all the extra for air freighting from Japan a new right front guard as the insurance company didn't want to pay it. Only very light damage, and they claimed they were Canberra's best panel shop. I told them to panelbeat it and they started moaning about the time and effort and they didn't quote for it. In the end they just got on with it and it looks fine still.
I saw some lead wiping once and it was magic. The guy was restoring a vintage lorry and he wanted to stay original with everything, even the panel work, so no filler anywhere.
Keep up the good work Troy. i look forward to seeing the finished product.
Yeah damn insurance companies... I had a tail-ender recently (ie someone ran into the back of me) and the insurance company didn't want to pay for a replacement rear bar and reinforcement, they wanted them both 'repaired'... might have saved them $20 on a $1500 job. I hate insurance companies.
Anyway, back on topic, this has to be one of the best threads I've seen in a long time, and it's good to see some people still take pride in their work. Cheers! :D
Once again another update....Now the bulk of the repair is complete and the smaller repairs have been done and hifilled the whole body is sanded with 240 dry and its masked up and hifilled in full heres a couple of pics ..will have some more tomorrow of underbody sealers and rubber under body coating being applied
underbody update....the rear section of the rail had been damaged due to jacking and the rear floor pan hasnt been planished up correctly after a previous repair so i ended up taking off the rear rail section and reshped it and re fitted it....then we re seam seal the underbody and spray it with a spatter gun to get the factory type sealer finish...then we match the factory grey undercoat and i have painted the underbody and misted the colour through the tunnel
there not weak....you are not supposed to jack a car from the rails....they have jacking points...if you have to jack it on the rail the best spot is where the front rail overlaps the intermediate rail...use a jack with a rubber coated cup not the full steel one
now we apply drip check to the new chassis rails where they meet the skirts,this keeps the moisture out from the join...next we match the factory phosphate primer and spray some over the top of the skirts and drift it out over the upper support beam to match the original stuff.....then we mix up some colour with matting base added to it this is dull off the paint in the engine bay and give it a satin finish...the material is then applied,this takes quite a while to make sure every nook and cranny is covered and make sure not to get runs and a uniform finish....the inside of the cabin has also been fitted with deadner sheets and is also painted....now the hard work is over,its time for the fun stuff....lets start assembling!!!
Will you even tell that the car has been in an accident once it is finished??
I really can't wait to see Sam's paint job.
Saw this other car that he worked on and it was great craftmanship.
Can't wait to see your car on the road Troy! :)
hey aaron...well the aim is to get it back to factory specs,so we can only do our best.I have to say that sam would have to be one of the best tradesmen i have seen,he really has been given a gift....At this stage i think i will paint the car and block it down and get old golden hands to give it the final coat.Which car did you see?
    • You can’t see much on the other side as the lcd is there I don’t think it’s the same as the m33 beside it as the markings on top is not the same was hoping someone had a good quality photo or if they just happened to have the unit in hand, quickly take the cover off and take a photo to clearly show the marking on top to identify the diode   the unit is currently with an electronics repair shop so I can’t take another photo at the moment hopefully they are smart enough to know if it’s a zener diode or not
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
