f**ken scum pinched my stagea tonight round half 6pm
was clublocked,locked and nothing of value in sight thro the windows
it's green mainly,matte black 260rs rear bar,260rs black sideskirts,blackfront bar
big black rear wing.am performance straight pipes hanging out the back
work radbotes,chrome dish (good luck selling these f**kheads,there the only set in the country)
keep an eye out lads,will update this wen I hear back from the cops
it's been reported,so I'll just have to wait now...
Guess I'm buying a gtr abit sooner than I expected
worst thing is I've been collecting parts to convert it to manual for a couple months now
was all ready to go this Sunday....
Farken gayness
https://www.sau.com.au/forums/topic/336354-stagea-stolen-tonight-magill/
  • Replies 140
Thats farkin ghey. I was just reading the other stolen vehicle threads thinking that my stag should be safe cause it's volvo spec..... not the case obviously.
you Got insurance to cover it? i'll keep an eye out for any cheap random green stagea parts!!!
and I take it from your post it didn't have an alarm?
FOR f**kS SAKE PEOPLE, EVERY (and I mean EVERY) SKYLINE THAT HAS BEEN STOLEN RECENTLY HAD NO ALARM. Use your brains and put an alarm in your cars ffs. This is beyond ridiculous - how many have to go missing before you finally get it?
wasn't this car advertised for sale at some point? did ya have any suss characters checking it out? and if so, did they suss it at your place?
Edited by Big Fella
Car is fully comp insured,hopefully justcars are good about it
Car was booked in for an immobilized and alarm install tuesday
car was stolen from work,I'm a chef so whoever stole it knew I was working there and that I'd be busy at that time
the exhaust is blisteringly loud,although I stand under a commercial range hood all night and we were getting raped tonight and were super busy
there's no way in the word I'd have even heard an alarm go off anyways,thought the clublocked would be sufficient for the time being
and nightcrawler,there's no need to be a dick all your life
guys are having there cars flogged all over the shop and all your doing is kicking them while there down
even if my alarm was fitted today,I wouldn't have heard it from inside the kitchen
wait till someone steals something of yours that you have poured thousands of dollars into,a shitload heap of work
not a nice feeling mate
especially wen you have paperwork in the car with your current address blah blah
try having your car stolen,then being super worried and rushing home to make sure your wife and 8month old boy are ok
f**k the car,my families safety is more important
who knows whether these donkeys would go down the path of robbing my house too
Edited by -RBD2-
Thanks chuck
good to get some support instead of wankers ragging on you wen your down
hope the big green girl with the fat black arse turns up soon
Edited by -RBD2-
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
