f**ken scum pinched my stagea tonight round half 6pm
was clublocked,locked and nothing of value in sight thro the windows
it's green mainly,matte black 260rs rear bar,260rs black sideskirts,blackfront bar
big black rear wing.am performance straight pipes hanging out the back
work radbotes,chrome dish (good luck selling these f**kheads,there the only set in the country)
keep an eye out lads,will update this wen I hear back from the cops
it's been reported,so I'll just have to wait now...
Guess I'm buying a gtr abit sooner than I expected
worst thing is I've been collecting parts to convert it to manual for a couple months now
was all ready to go this Sunday....
Farken gayness
https://www.sau.com.au/forums/topic/336354-stagea-stolen-tonight-magill/
  • Replies 140
Thats farkin ghey. I was just reading the other stolen vehicle threads thinking that my stag should be safe cause it's volvo spec..... not the case obviously.
you Got insurance to cover it? i'll keep an eye out for any cheap random green stagea parts!!!
and I take it from your post it didn't have an alarm?
FOR f**kS SAKE PEOPLE, EVERY (and I mean EVERY) SKYLINE THAT HAS BEEN STOLEN RECENTLY HAD NO ALARM. Use your brains and put an alarm in your cars ffs. This is beyond ridiculous - how many have to go missing before you finally get it?
wasn't this car advertised for sale at some point? did ya have any suss characters checking it out? and if so, did they suss it at your place?
Edited by Big Fella
Car is fully comp insured,hopefully justcars are good about it
Car was booked in for an immobilized and alarm install tuesday
car was stolen from work,I'm a chef so whoever stole it knew I was working there and that I'd be busy at that time
the exhaust is blisteringly loud,although I stand under a commercial range hood all night and we were getting raped tonight and were super busy
there's no way in the word I'd have even heard an alarm go off anyways,thought the clublocked would be sufficient for the time being
and nightcrawler,there's no need to be a dick all your life
guys are having there cars flogged all over the shop and all your doing is kicking them while there down
even if my alarm was fitted today,I wouldn't have heard it from inside the kitchen
wait till someone steals something of yours that you have poured thousands of dollars into,a shitload heap of work
not a nice feeling mate
especially wen you have paperwork in the car with your current address blah blah
try having your car stolen,then being super worried and rushing home to make sure your wife and 8month old boy are ok
f**k the car,my families safety is more important
who knows whether these donkeys would go down the path of robbing my house too
Edited by -RBD2-
Thanks chuck
good to get some support instead of wankers ragging on you wen your down
hope the big green girl with the fat black arse turns up soon
Edited by -RBD2-
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
