Hi mates :P
I'm looking for some one that can build a skyline head for about 800hp @ 10000 rpm's. please provide contact
Can you list items that i would need before i spend the big bucks. :)
  • Replies 60
Posted Images
this should do it for u if u can get more details, they have come down in price abit as well i was looking around a lil while ago and they were about 1000 more.
http://www.spoolimports.com/content/NISSAN...EADSFORSALE.asp
Depends what you want done.
Are you after parts or just head machining?
To keep it simple, i think it would be best for the machinist to pick the parts and do the work. I just pay. Port and polish valves, guides, springs, retainers combustion chamber reshape, valave angle job, solid lifters, cams, etc.
bullet in SA, its where most decent 26 heads from around the country end up.... best work ive seen on rb26 heads so far. CNC ftw everytime
http://www.bulletcylinderheads.com.au/nissan_rb26.php
+1 for Paul @ Red R Racing
[email protected]
top quality workmenship and knowledge..
thanks everyone, i contacted paul I'm giving hin all my specs now, for a price quote. Anyone have an idea on the price for machining and parts.
Thanks again mate
Heres another example of his fine work this is his stage 3 race porting. I have currently have my engine being built buy paul now and all i can say awesome workmanship and knowledge and top bloke.
Hi mates :P
hi mate i just built my motor for that power plus.. Envy imports at brookvale 9907 4144 they have built plenty of these heads mine will rev to about 10 500 rpms give herman a call and get the details off him iv done all the port work bigger clearances for the cams which are 290 degree jun cams all the valves buckets shims etc go to envydyno on youtube to see there work
10500 rpm, craazy, hope your oil pump and bottom end will hold up
The best place i found so far is http://www.theoldone.com/components/cylinderheads/skyline/
I think these guy's are the best. check it out and let me know. the work is clean as it can ever be. A mirror shine mate.
I hope you are not deciding what is "best" based on a clean, mirror shine... :P You need to use their custom pistons with that head too.
Are you located in Australia? I would definitely consider a local company before sourcing something overseas.
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
