In general, owners in Japan will do a timing belt change just before the 100,000k's mark.
To be safe I would just change it, regardless.
I had a Nismo timing belt and I changed it as soon as I got the car to a OEM (Nissan) timing belt.
A 100k service isn't going to be cheap :D
Depending on how much money you have available it may be best to park up the skyline (before the timing belt goes). From there you can slowly collect up all the parts required and then just find a local workshop to do the labour. The kms could have also been wound back further at import....
You really need to do the following:
- AC Belt
- PS Belt
- Alt Belt
- Timing Belt
- Water Pump
- Spark Plugs
- Clutch (Full Kit Ideally)
- All Fluids
- All Filters
- New Battery?
ect.
You could get away with just the clutch and timing belt for now, if things are failing it's most likely sign everything is pretty well worn.
Edited by Pandoraa
unless the clutch is slipping, forget about it. same goes for the battery. unless it is dying, leave it alone.
belts, yeah maybe, depending on condition of the ones on there (excluding timing belt).
timing belt, yes, and make sure the tensioners are done too.
fluids, yes.
water pump, yes, best to do it while you have everything apart.
spark plugs, depends on how old the ones you have in there are.
- AC Belt
- PS Belt
- Alt Belt
- Timing Belt and associated tensioners and guides
- Water Pump
- Spark Plugs
- All Fluids
- All Filters
- New Battery?
thats all he needs to do. the rest can be done on your own, at normal service intervals as you see fit. 5000kms for oil/filter. 10k kms for copper plugs, etc
Edited by Munkyb0y
It's my daily and I'm still looking for another car, but I'll get it done soon.
- AC Belt
- PS Belt
- Alt Belt
- Timing Belt
- Water Pump
- Spark Plugs
- All Fluids
- All Filters
- New Battery?
ect.
Spark plugs, filters and fluids I do myself. Battery has just been changed and clutch is slipping so I'm organising an upgrade to be put in. I just have no idea what has been done before, so I might do all the belts and water pump...
as monkeyboy has said the sticker is not always an indication that the 100k service has been done. mine had the sticker but i did service anyway to be safe, and by the look of the belt it was the original from the factory.
when my 100k sevice was done they replaced-
timing belt
water pump
cam and crank seals
idler and tensioner bearings?? (i believe it was both, but could be wrong)
all up the sevice cost about the $900 mark. im sure if i wanted to i could have found someone to do it cheaper.
This is one of those times I really wish I was a good mechanic.
I might buy one of those kudos kits
http://www.kudosmotorsports.com/catalog/ni...25det-p-91.html
And I guess the AC/PS and alt belts are all nissan so I'll hit them up for a quote. I think that'd cover it all.
Thoughts?
Btw did oil today and when I can undo the fkn plugs will change the gearbox and diff oils.
Then there's only clutch and brake fluid right? Does the clutch fluid have to be done with the new clutch? I might get the brake fluid done when I get new pads, which is also going to be soon.
Money Money Money...
Thoughts?
Yeah just coolant in the radiator which would obviously be done with the water pump and belts.
Probably wouldn't hurt changing the power steering fluid also. That ones reasonably cheap/easy.
it's a skyline, not a space rocket. any normal mechanic with half a brain will be able to do the work. half the stuff won't be that much different to a VL commodore, and i'm sure he's worked on newer, more advanced motors than a dirty old RB.
Should I be replacing these too? (Along with the kudos kit and AC/PS/alt belts and fuel and air filters and cabin air filter and all fluids)
Timing belt bearing stud and bolt kit 22.00
Seal Kit, Cam Cover 93.50
Bolt & Grommet Set, Cam Cover 55.00
Harmonic Balancer 339.90
The harmonic balancer seems pretty costly.
Cheers
  • 1 month later...
As above. No need to change the balancer, battery or clutch unless you have issues with those items. My cam covers were leaking so I got the seals so i could change them all at once. If your changing your plugs with platinum ones and have leaking cam covers change the seals now. it will save you time pulling it all apart to do the seals. I also changed every fluid. Clutch, Gbox, Diff, Coolant, P steer and brake fluids. You never know when it was changed last otherwise.
I bought all my gear at once from Kudos and he gave me a few free upgrades and threw in a few goodies. Message him and let him know what you want. i changed my mind and ordered a heap more and Andrew sent me the goods and let me pay him a week or so later. Not many people would do this. Top bloke. Would recomend anybody at least gets a price from him.
I got the whole Nissan Timing Belt kit and Nissan water pump with nissan seals, Timing belt stud kit, Cam cover gasket set, Ancillary drive belt set, NGK plugs and he threw in a Greddy oil filter. The stud kit is a good idea as theer are stories of them snapping if reused.
Cheers for the info, the hundred thou sticker was in a random place so the service had been done, luckily.
I had everything ordered with kudos before a mate pointed it out and Andrew was happy to change the order for a clutch kit. Great guy, will go to Kudos first for whatever I need now...
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo :-D
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
