weird noise from turbo?
I'm with Kinkstah. Good ECU so you can tune some of the shittiness out of it. Secondly, if you want cheap, look at something like Speeduino.
I'd make the argument that "Just a daily" is what needs the real engine management and real tune for it's driving around casual needs. You can cut corners when you DGAF for dailying or road use on a car.
Of course a Link is the better option but $$$ which for what is meant to be “just a daily” might be overkill.
First run had some woofs of black smoke then went away for this one I filmed. General driving i tend to see 10.2-11.5 on my gauge. Still gets 8L/100km. I should leave it alone and just drive it around but now i am considering a the 2 options of either FCD + RRFPR and see if a little more boost and some fiddling gets the AFRs more reasonable. Or option 2 looking out for a cheap Link ECU to wire in as standalone...
