  • Replies 105
Yeah but wouldnt i have to take it to melbs for the emanage anyway to be tuned ? :) (im in brisbane)
that can come later..and the ecu compared to a nismo is cheap.. emanage ultimate $899. nismo ecu - $1250
i want plug and play i mean plug and drive! for the time being :down:
S/H Emanage Ultimate with loom cost me $650. Cihan gets up there occasionally, you could get a group buy on install and tunes. :)
You have to understand, the Nismo is not a specific tune for your car. It may handle exhaust, perhaps cooler but any highflow or intake mods and the tune will drift far from satisfactory.
Where are people getting these HDI kits from for M35's who can source them ? ive seen the blitz ones online.
and RS4T .. the fcon - wouldnt that be suited for a c34 not an m35? its either impul,nismo or a tune for an emanage i believe.
HDI are in Sydney and you can contact then off this forum. Do a search for HDI.
Price I believe is around $900 with the slimmer fan included.
If you can find them let me know and I will find a ph number for you.
Cheers
Andy
Nup, if you have a good tuner for it the FCON is the preferred piggyback for M35 considering it has a plug and play harness for VQ25det.
Problem is finding a tuner that ISN'T in Sydney :)
For HDi's contact details, see the other thread: http://www.skylinesaustralia.com/forums/in...t&p=5445568
Edited by iamhe77
tuner is in Sydney I spoke to him about a month ago....he a mate of Prep'd!.....but his not doing it anymore.......he go sued for selling Chinese takeoff's of the product!
is no body clicking this link??
http://www.importmonster.com.au/view?url=h...pro%2018%20APEX
you dont need a hks dealer tuner for fcon... haha
and i have a similar thing to the above for my 32 gtr.
Ive done some research on here regarding tuning the fcons, and Im just a skeptic really - its a fair punt for something that mightnt work at all. Admittedly most of the posts regarding the Fcons are from 2007 or so, but they all seem to indicate that people have tried to buy the software/keys for the software and it hasnt worked.
Just to clarify on your last statement mate, do you have an FCon in your 32, and have the software installed on your laptop to tune it yourself?
Correct. i've had it for years now. no key or anything required..
my only problem is its japanese. but you can still tune and do most things easily.. can also use all the data log features and read them easily. i had a friend touch up my map a little also with a japanese reading friend to help assist.
when i get the car back together, i will spend the 300 or whatever and buy what i have posted in the link above to get the english versions.
What about these guys - www.g-zone-r.com
I noticed one of their chipped VQ25DET ECU's on Yahoo auctions. It seems they tune all the M35 ecu's out there!
I wonder if they could pass on some technology to SAS or someone so we can have ours chipped here. Im sure they could do a simple chip with boost and speed limit cut...
Edited by bbenny
All remap services are a re-flash... not so much a chip from what I have gathered... oh, and it is hard enough to get them to respond to a remap request with the requirements laid out in an email, let alone getting in a conversation with them about selling one of their readers.
they are a remap service, require your ecu (and maybe car also) for this service. service is located in japan :cool:
G-Zone don't require your car, nor do Mine's, Impul, Ks etc.... only Nismo do (Damnit!)
Edited by iamhe77
PM sent
Edited by iamhe77
hmm sounds like my best option is either seeing if a local can tune it or taking it to sydney for a fcon-v tune or melbs for an emanage.
hmm im hoping someone in qld has tuned these to some degree.. i dont care what ecu. if the fcon-v can piggy back and be tuned correctly so be it. as long as it can be done and im no test pilot ending up with a failed combo.
Call GTAuto in Brisbane, iirc they can tune Fcons.
found the harness connector at this link and its part number for the fcon-v
http://www.ooparts-international.co.jp/ind..._con/index.html
Model - Engine - Year - P/N - Price - Harness
NM35 | VQ25DET | 01/10 | 42002-AN004 |35,700 | NP5-15
Edited by PetroDola
Nah, it is looking like the F-con will have a tuner in Melb soon.... possibly :)
    • I am getting the same issue. Did you resolve it? I just got it after installing my new super coppermix and literally the same issue, new fork, new 18mm carrier, release bearing that came with the kit and replicated the exact same sound.
    • If you like - I have the STL files so I can email em. There's a couple of gotchas (i.e the holes are not threaded so you might need/will need) to utilize some M3 melt-in threads for some of the points. However if you want to be super accurate, and are willing to remove your calipers and your SHOCKS it's a really good tool. You also might need to scale the part that measures the tyre width a bit wider. It defaults to a 7.5in tyre and I mean who is running that. Luckily with the magic of CAD this is very easy to rescale.
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
