As the topic states
If you were in charge of directing the next FnF movie. What cars would you put in it? What would the plot be? What location would you shoot?
Sorry guys, I'm bored at work and couldn't think of anything else to do.............
  • Replies 90
Posted Images
Base it in the 90's and fill it with R32's, R33's, Silvias, RX7s, Evos, Supra's, 300zxs, etc.
Make it somewhat realistic too. E.g. It would've been so much sweeter if that Ferrari smoked the Supra off the line only to hear the spool of a ridiculous turbo winding up and send the Supra flying past.
i'd like to see more sleepers and less ricers.
also i'd like it to be more realistic as well. none of this neck and neck racing and then having one car drop it back a gear, floor it and just pull away. what sort of cockhead races just to keep up when they have the power to just floor it and blow past them?
Yep that is definetely the most annoying thing that they do. It just doesn't make sense.
In saying if there was another, did you really mean in the next confirmed installment...?
http://www.filmofilia.com/2010/02/04/fast-...tails-revealed/
http://fast-and-furious-5-movie-trailer.blogspot.com/
Edited by TUFF_350
No shit, had no idea it was confirmed!!! The first couple of photos though.... Looks like a movie set in the bronx.. Haha, gangsta as
hahaha is this chick supposed to be pregnant? coz she looks like she's just carrying a basketball under her clothes.
motor is too small
needs more kit
not enough armour
Edited by Munkyb0y
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
