i have a spare rb26 balancer here (brisbane) if you want - they work great!!
Otherwise the cheaper aftermarket option would be from ROSS -> http://www.rosstuffbond.com.au/metal_jacket.html
I got my ATI balancer brand new delivered from the US for cheaper than a Ross would have cost locally.
$500 to my door for the ATI vs $572 + delivery for the Ross Full Metal Jacket.
Both will do the job, just see what you can get the best price on.
My mates running a Ross on his Tomei RB28 without drama, Godzilla motorsport drag car runs an ATI and that thing revs like crazy...
ATI, with the AUD being so good against the USD www.summitracing.com have them for a good price.
918598 - STREET: R33 & R34, P/S, A/C, Alt Up to 500HP All Pulleys are in OEM locations. Power steering pulley is 15% underdrive, alternator and water pump are 5% underdrive. A 10mm shorter belt is required for power steering pulley. Damper shell and pulley are aluminum with steel hub. Be sure to check your crankshaft for roundness. If it is equal to or more than .001" out of round, you will need to adjust for proper damper press fit.
http://www.summitracing.com/parts/ATI-918598/
917753 - STREET: R33 & R34 P/S, A/C, Alt, 600–1000HP Damper includes new aluminum water pump pulley for clearance. A/C belt is a 25% overdrive - DO NOT USE BELT IF RACING! 15% underdrive on power steering, OEM size on water pump.
http://www.summitracing.com/parts/ATI-917753/
Cheers
Johno
i think the gtst power steering pumps may pose a small problem.. different ribs on the pulley and i believe its a slightly different offset, as i had a bit of trouble fitting a gtr pump to a gtst
Are the ross drift ones any good?
i would get the ross one. local and they do a nice external crank trigger set up aswell if you ever need it. no orings to replace and doesnt have the belts running on the damper part of it. (bad if they do)
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
