hi guys,
me and my mate installed a lt10s into my rb20 over the weekend, started it up, and with the base tune it seems like its idling weird. kind of pops/knocks. . .
tps is showing 0% load.
also im not 100% sure that the knock sensor is hooked up correctly either. . . can anyone post up the wiring diagram for the tps sensor/switch?
i have read that on first start you have to adjust the tps? and lock in the timing??? any suggestions on how to go about??
Any help is appreciated! cheers
https://www.sau.com.au/forums/topic/337967-microtech-rb20det-install/
Use hand controller to lock timing - Do not rev the motor!
Use timing light to set engine to correct base timing by adjusting the CAS.
When timing is set correctly, unlock timing with the hand controller.
You have the Microtech manual right?
Also the Microtech doesn't use the knock sensors.
Edited by PM-R33
ok, so ive sorted out the tps. microtech is showing 0% then 99% with throttle.
im still not 100% about the CAS wiring. . .
Also, since ive relocated my battery to the boot. when i switch on my isolator switch, sometimes it seems like the coils spark and it even pops! any ideas on what i should check??
Cheers!
Also, since ive relocated my battery to the boot. when i switch on my isolator switch, sometimes it seems like the coils spark and it even pops! any ideas on what i should check??Cheers!
check yellow pages and find an auto elec in your area
but it really is, for the time it takes and people trying to diagnose it over the net without realtime testing and by the sounds of it there is some major issues with how ever it has been wired up.
all the diagrams needed are on the microtech website, we get guys ringing 10000 times a week with similar issues and it is always wiring related, so unfortunately we just refer them straight to a dealer of whichever product it is. I dont take on half wired jobs as it often takes longer to fix than a new install...
jump on the microtech website and check you cas wiring to their diagrams
http://www.microtechefi.com/pdf/LT12NISSAN6CYLign.pdf
hey trent, its got a base map on it, ive gone through the tps set-up and adjusted the timing to 10btdc, but its still running really rough. is that common?
Edited by I8EE
whats the idle af?
A microleb is a downgrade from the stock ECU, personally I'd sell it. They don't have closed loop O2 feedback so you are going to get rubbish economy unless someone spends hours and hours on the lower load cells when tuning it.
its a dedicated drift car, so i dont care for economy lol
pulled the plugs out trent and there soaked in fuel....thats base mapping for ya.... gonna chuck in the 750's i got and bring it in on the 9th
yeah its showing 14.7 on the h/c. tried trimming it down to 20% but its still rich. . . plugs are soaked in fuel. . .
ignore that, its about 1000000000000000000000 light years off being accurate. use a real lambda sensor or lean it off in steps until it stalls then about 2 page up steps will get it idling if the wiring etc is all correct
Agreed. Just keep trimming it down. Is the vacuum/ boost line connected?
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
