  • Replies 407
Posted Images
It was a bit more than that, it’s a 4 shot panorama with every frame a 2 shot HDR image and various minor tweaks in Photoshop.
PS: also had to correct verticals in PS as all the building were leaning in
Edited by bnr#@
Singapore skyline...
(quoting as it deserves to be on this new page, lol)
awesome!!! love the reflections in the water. and i know how hard it is to correct perspective changes by hand. top work! well done man.
this was pretty random. was down at the beach today and there was a couple sitting at the picnic tables with their snake.
as soon as they invited the kids to give it a pat my kids wouldnt leave it alone, lol. not something you experience every day.
im loving the Lumix. always ready when you need it.
^ OMG!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
SNAKE!!!!!!!!!!!!!!!!!!!!!!!!!!
Edited by siddr20
Teaser pic from Kristyn's yesterdays wedding. Just a random pic i opened up. Havnt even had the chance to look at the others.
Would also like to thank kory and Joanne for helping out yesterday.
Cant wait to process the rest of the pics!!
Looks like a fun bunch :) Very photogenic hehe. McLovin the colours you've given it and how you've blended the champange colour dresses with the sky. nice touch.
Probably one of my hardest wedding gigs I have done I reckon. Well im glad you liked it :D Cheers dude.
Some pre-wedding photos can be seen here: http://sidd-rishi.com.au/blog/2/pre-weddin...-wedding-shoot/
so many great shots from today! will throw some favs up in here later. going to bed now. check flickr for a few.
also, in case you didn't know there's a massive difference in quality between pics hosted on flickr, and picasa. Might be common knowledge but news to me.
flickr
Picasa
Flickr
Picasa
Sidd, they're the same pics, I hosted them on both flickr and picasa and was amazed at the quality difference between the two hosts. i wanted to keep flickr pretty clean and only throw favorites up there, but picasa makes everything look dirty compared to it. ;/ grrrrrrr
nice watch, the dali one is good too! You need to get out more, my dear friend :D
SNAAAKEEEEEEEEE! Was it a solid snake?
nice watch, the dali one is good too! You need to get out more, my dear friend :)
I know I do; I'm so totally wrecked after yesterday though, can't believe I'm awake right now. Got some OK-ish shots, I just don't think my head was in it yesterday. Blah. Haha, totally freaked me out when you slapped me but I worked it out quick enough :D
lol. if it was, it moved pretty damn good for a solid snake. at first i couldnt believe it was real, the bloke who owned it even said it was remote control and i believed him for a second, haha.
MUSHROOM.. MUSHROOM...
Badger, Badger, Badger, Badger...
(Sorry couldn't resist) :D
I was going to slap you too, but decided that you were pretty freaked out after Matt slapped you and didn't want two slaps in a row. Your missus looked horrified as well lol..
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
