Car looking all nice and shiny!!
OMG, yummmmm!!! Where's the Chaser badge on the front though, Sidd?
Eric, I still haven't looked at the video I took on Sunday, but I'll give it to you Thursday if you're coming out.
  • Replies 407
Posted Images
That looks really col Jay! Only just noticed it now. Did you do the graffiti as well? I assume you did judging by your comments?
Owen - Maybe piss turns glow in the dark when its baked into the paint? Who knows.
Have you checked your oil lately? We may have drained the sump...accidently of course!
Or maybe we stuffed your girlfriend into the fuel tank... But that's a bit far-fetched.
Edited by FST513
She came up to my office this morning so I don't think so :( And uhh, checking oil... no. Only time I check that is when I flush it :)
Blah, I'll figure it out tonight... maybe. Brought my camera to work today with the idea of going and taking some shots in the Uni at lunch; pity it's a shithouse day.
Maybe we flushed it for you? :(
Tip: Use a black light.
Clutch - I think it looks good. Really moody. Maybe you can use a layer mask and brighten the flower up so the yellows pop a bit more?
thats a good idea, i dont know much about photoshop, how do i go about this? and can it be done in lightroom? (i dont have ps installed)
I really should just write a layer mask/adjustment brush tutorial LOL. I've explained this at least 15-20 times haha.
But in summary.
Crank the levels up/curves so the yellows are brighter and poppier.
Down the bottom of the layer palette is a camera look icon. Click this.
Change colour palette to black and white (Shortcut key: D). X changes between primary colour & secondary.
"Paint" in what you want selectively. Or you can press CTRL + I (on PC) or Command I (On mac) and this will invert the mask so it will be your original image still and then you can just paint the flower (Easier for you as you only want to do a little bit of the image not the entire image).
In lightroom:
Go to the develop tab
At the top underneath the histogram, click the brush.
Make sure you choose exposure, paint the flower with the brush. I think its the same in lightroom as PS, to increase brush size is the ] key and the decrease is the [ key.
You can then slide the exposure around once you have found what you want.
You can then paint in extra contrast etc etc...
Hope this helps :(
But in summary.
In lightroom:
Hope this helps :(
cool thanks, will try it out tonight and repost!
Yeah, I had some left over paint in the shed so thought i'd have a go. Ran out of white tho as I only had two 1/4 full cans.
But found a few good pieces to light paint, just got to work out how im going to get there as the skyline is playing up. :'(
Which batteries you talking about? Your box of thieved batteries from work or the ones you took out? The ones you took out you put back in that bag with your 6million year old flashes.
I checked all my bags and i don't have any batteries. If you did lose them - Get eneloops!!!! You'll never be changing after them i tell ya! Recyle time will be SO much faster on your 6million year old flashes. If there not, i'll pay for the eneloops thats how good they are.
Jay - Ahhh ok. I got a question for you. Obviously graffiti isn't done in publicly lit streets (Well pieces like yours). Do you go out to these random places by yourself and do you ever sh!t yourself??? Some places look so dodgy!!! I'd be sh!tting myself!!!!!
I'll only buy you some Sidd if your energizer batteries are faster than eneloops :down:
You can buy them at dick smith or online. I think its about $30 for a 4 pack. Buy two packs of them and it'll be the best $60 you ever invested!!!!!
Oh and where was your battery pack for the wedding on the weekend, i forgot to have a look at it.
they look dodgy, but most times i've been there during the day and that makes them feel pretty safe for some weird reason. i consider the tunnels the safest as its not that likely that you'll run into anyone. i guess i dont really think about it much.
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
    • It's amazing how well the works on the leather seats. Looks mint. Looking forward to see how you go with the wheels. They do suit the car! Gutter rash is easy to fix, but I'm curious about getting the colour done.
